BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
05-06-2018, 05:33 PM | #1 |
Drives: DGM 15' BRZ Limited
Changing oils by myself, are these a recommended jack+jack stand?
This would be my first time changing oils by myself and using after market jack and jack stands. 2015 BRZ
For jack stands, would the double locking Torin be preferred over the regular? Or is there a completely different brand you would recommend? Torin- https://www.amazon.com/Torin-Big-Ste...pSrc=srch&th=1 Torin double locking- https://www.amazon.com/dp/B00026Z3EA...ing=UTF8&psc=1 For the jack to lift up the front/back of car Pro Lift F767- https://www.amazon.com/Pro-Lift-F-76...words=car+jack Thank You |
05-06-2018, 06:26 PM | #2 |
Drives: 2017 BRZ
Not going to lie, I'd spring for the double locking... I'm always a wee bit paranoid. I've also been using the standard ones for years (as do so many other people), so that paranoia is likely unwarranted.
For the jack, do yourself a favor (though yes - it's a good deal more spendy) and get an aluminum jack (unless you never ever ever plan to take your car out where you might be wanting to change tires at the event... track, autocross, drifting, whatever.) I like the Arcan 2 ton, bit more reach than the 1.5 ton, though a bit heavier and more $: https://www.amazon.com/Arcan-ALJ2T-A...dp/B00132CGEW/ Also, just so it's out there. NEVER use the round/hexagon base jack stands.
05-06-2018, 06:28 PM | #3 |
Drives: '13 DGM BRZ Limited
If it's just for oil changes, get some Rhino ramps from Pep Boys.
Sent from my SAMSUNG-SM-N910A using Tapatalk |
The Following 7 Users Say Thank You to cnk For This Useful Post: | Busybee (07-31-2021), PenGun (04-13-2021), ScoobsMcGee (05-08-2018), Spuds (05-06-2018), Teseo (05-07-2018), Ultramaroon (05-07-2018), Yoshoobaroo (05-07-2018) |
05-06-2018, 06:38 PM | #4 |
Drives: 2016 Subaru BRZ
I have ESCO 10498 Jack Stands and use a hockey puck with a line cut down it to place on the pinch weld, works like a charm. I went with these because they have a wider base, four leg jack stands have a narrow base and will do a tripod dance when you use them on a slight incline.
05-06-2018, 07:18 PM | #5 |
Drives: 13 FR-S
The ESCO stands are pricey but simple, robust and stable. I always grab them first. The new Harbor Freight Daytona jack is a beast with a big low to high range. A virtual copy of Snap-ons, coming out of the same factory. Its also a 100 lbs, so it aint portable.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
The Following User Says Thank You to gutbuster For This Useful Post: | Wally86 (04-12-2021) |
05-06-2018, 08:22 PM | #6 |
If you want to save some money the Arcan-XL20-Black-Jack is $140 and goes down to 3 1/2 inches, but it's only a 2 ton jack.
05-06-2018, 09:56 PM | #7 | |
Also, any recommendations on a jack that is <$100? The ones above suggested look great, but I'm not looking for the top of a line jack, it's a tool I will be using most likely 3 times a year at most. Just something to lift up my BRZ so I am able to put the jack stands in to change my engine, trans, and diff oils, rotate tires. My vehicle is only used as a daily driver for work, no racing or anything exciting lol Last edited by btan219; 05-06-2018 at 10:06 PM. |
05-06-2018, 10:13 PM | #8 |
Thanks
Trolly jacks are a waste of money imo, just go to harbor freight and pick a nice floor jack and a couple 2+ ton jack stands. You wont regret it.
The Following 5 Users Say Thank You to ZionsWrath For This Useful Post: | Mr.ac (05-07-2018), Pat (05-07-2018), ScoobsMcGee (05-08-2018), Spuds (05-06-2018), trippinbillies40 (05-07-2018) |
05-06-2018, 10:48 PM | #9 |
The Dictater
Drives: '13 Red Scion FRS
I have a pair of old inherited torrin dual lock stands holding up the front of the car right now lol. And a pair of cheap HF holding up the rear. They work fine. I'd spring for a set of 4 torrin dual locks at the 3 ton level (at least) if I were to do it over again. The torrins definitely have better welds on them, though the HF I'm sure will be fine. I believe in having the largest factor of safety when my life depends on it.
Floor jack isn't a life or death thing if you are doing things right. My recommendation is to get a low or ultralow profile steel jack from HF (I have the former) Yes it's heavy, but when are you really going to need to carry it around? Wish I had the ultralow profile, but mine was a gift so . Problem with the low profile one is it's about an inch too short lengthwise if you want to lower the car at all. Edit, one more thing to note is that i believe stands are rated by the pair nowadays. I believe my torrins are old enough to be rated individually at 3 tons per stand, which would put them at the 6 ton set for sale today, but I'd have to go check. Not that it matters for an 86, but just a note to read the fine print before using them on anything else. |
05-06-2018, 10:57 PM | #10 |
The Dictater
05-06-2018, 11:31 PM | #11 | |
Drives: 2017 BRZ
The Following User Says Thank You to Brink For This Useful Post: | Spuds (05-06-2018) |
05-07-2018, 12:05 AM | #12 |
The Dictater
One more thing. I always lift with the e brake disengaged, which might be counterintuitive. Reason being that you get less front-back motion when lifting and lowering. The car is going to rotate about the rear hubs in either case, but if the wheel isn't forced to rotate with it (by ebrake) the car won't be forced to roll backwards or forwards. If you are on a level surface and use wheel chocks it's not going anywhere anyway.
I used to lift with ebrake on, but when I lowered the rear, the front jacks (the torrins) would tip up on the front two legs because of the car's motion. It was super sketchy so I stopped using the ebrake and it didn't happen again. PS. Get a pair of cheap wheel chocks. |
05-07-2018, 07:07 AM | #13 |
05-07-2018, 09:12 AM | #14 |
Drives: 2017 BRZ
Well, the round bases roll if not perfectly flat on the ground. So those are the really risky ones. If one ever starts to go it can bring the car down.
The flat base hexagon version is safer, but I'd never use it outside of a garage with a smooth floor... Defeating the purpose of getting such a light stand in the first place.
The Following User Says Thank You to cjd For This Useful Post: | Spuds (05-07-2018) |
Similar Threads | ||||
WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-26-2015 11:03 PM |
Custom made Jack stand supports | AlexTheGreek | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 03-04-2015 05:01 PM |
jack stand body contact behind pincheld | tjc5268 | BRZ First-Gen (2012+) -- General Topics | 2 | 04-12-2014 04:15 AM |
Jack stand points | xxscaxx | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-12-2013 09:01 PM |
Jack/stand system | Mr.Corvus | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 03-31-2013 12:02 AM |
