Old 06-25-2018, 12:48 AM   #1
FewTooManyBeers
FewTooManyBeers's Avatar
Drives: 2015 Scion FR-S
Question Wheel Question on Stock Shocks
Hello, I'm looking to upgrade to 18" rims, on Stock suspension. I currently have stock 2015 Scion FR-S rims and everything else. I don't quite understand the whole Offset, Camber, ect deal. Total noob.
My choices thus far are:
- TSW Nurburgring RF 18x8 / Offset 35 alt. 18x8.5 / Offset 45
- Enkei Raijin 18x8 / Offset 35 or 45 alt. 18x8.5 / Offset 45
What I wan't to achieve is flush look, or sticking out a bit, but flush is preferred on the Stock suspension, I don't have money for Coils at the moment. Can someone give me more feedback.
Thank you.
FewTooManyBeers is offline   Reply With Quote
Old 06-25-2018, 02:04 AM   #2
Impureclient
Drives: 2015 FR-S
Your question is too broad. You need to narrow it down to exactly what you want then choose the wheel(if that wheel will even achieve what you are looking for. You'd be better off starting with a real thorough search in this wheel section and look at other cars with that size/offset to begin with. Also if you are changing to coils then that will change everything later for fitment. I'd start with looking at a online wheel calculator thing like this: https://www.willtheyfit.com/
Then you'll know where you will be by inputting the stock wheels and check what will happen with those wheels you are looking at. You'll want to be close to 20-30mm more poke to be flush. You still will want to either see in person those size/offset wheels on another frs/brz/86 if there any around you or just use other pictures in here with the size/offset you want and pull the trigger.
Be warned: Unless you are OK with spending money on wheels/tires/coils/spacers/LCA/camber bolts/springs/etc. and changing it later and spending more money after you realize you should have spend money differently in the beginning, I would say do a lot of searching in this wheel section to see other peoples rides to start with.
Did I mention searching in here and looking at other peoples wheel/tires/suspensions?
Impureclient is offline   Reply With Quote
enkei raijin, frs, rims, tsw wheels, wheel fitment
WTB: Stock Shocks JGalp Want-To-Buy Requests 2 06-14-2017 08:12 AM
Stock suspension wheel question appa234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-12-2016 06:18 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 08:31 AM
Pro-Kit on stock shocks B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-21-2014 10:05 AM
Tein springs stock shocks Qem wheel Ocho Seis Canada Classifieds 9 02-04-2014 12:11 AM
