Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
08-28-2018, 07:14 AM | #1 |
Drives: 2013 FRS
Temp removal of pass seat (airbag light)
I am about to foster a large breed dog, and will need to be able to transport him around from time to time. Unfortunately, the FRS is my only car, and the dog doesn't fit inside on the front seat.
If I were to unbolt my passenger seat, and run the car periodically with no passenger seat, I realize I will get an airbag light while it's out. What I'm wondering is, when I reinstall the seat, does the light go out on its own? Or would I need to follow up each "seat removal" with a trip to the dealer to have the SRS module reset? Thanks! Mike |
08-28-2018, 07:24 AM | #2 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
[ame]https://www.youtube.com/watch?v=ZB1fQyeorS0[/ame] |
08-28-2018, 07:45 AM | #3 |
The airbag module should recognize when the seat is back in place.
08-28-2018, 12:16 PM | #4 | |
humfrz |
08-30-2018, 09:27 AM | #6 | |||
If you buy an OBD-II ELM 327 and also buy the carista app on any smartphone, you can disable the airbag light before the seat removal. When you reinstall the seat you re-enable it and you should be fine. It's also able to be done through techstream easily if you have a usb-ob2 cable compatible with techstream. Also it's honestly worth it getting a bluetooth OBD-II dongle and some obd2 app on your phone with it at this point, it's kind of indispensable at this point in the automotive world if you ever want to fix things yourself.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Tcoat (08-30-2018) |
08-30-2018, 10:26 AM | #7 |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
I have removed the passenger seat in my FR-S to haul a toolbox, and also lumber.
So i've done it twice at least. While driving without the seat, the light is on and the car beeps at me. After reinstalling it, the light turns off and everything seems fine. I have not "tested" it by crashing my car and seeing if the seat airbags work.
NARFALICIOUS
Noob Poster 1988 | 2016 |
The Following User Says Thank You to NARFALICIOUS For This Useful Post: | qcbaker (08-30-2018) |
08-30-2018, 10:39 AM | #8 | |
The Gunshine State
Drives: '14 BRZ Limited
Well, what are you waiting for?? Lol.
Current DD: M235i |
The Following User Says Thank You to 8RZ For This Useful Post: | qcbaker (08-30-2018) |
Similar Threads | ||||
BRZ / FRS Seat Swap - No Airbag Light! | JohnPayneFun | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-23-2018 02:27 PM |
WTB: Resistor for Aftermarket Seat Airbag Light | KPDoubleX | Canada Classifieds | 9 | 05-01-2016 03:57 PM |
WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module | 14_GT86 | Want-To-Buy Requests | 3 | 04-01-2015 12:26 AM |
Side Airbag light with aftermarket seat? | Hanakuso | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-09-2014 03:20 PM |
Airbag light stays on after removal/reinstallation | Pablitomarrero | Issues | Warranty | Recalls / TSB | 13 | 04-04-2014 08:34 AM |
