Old 07-28-2012, 02:17 PM   #1
SpeakBeck
Drives: SRT4
Wiring Colors/Locations for the FRS
These are the wiring colors for the 2013 FRS obtained from Audiovox. These have not been personally verified, but Audiovox is usually spot on with their information.
This would most likely be a good thread to sticky at the top of this forum.
**I take no responsibility for this information. It is your duty to verify the wire before installation.**
SUBARU BRZ WIRING MAY DIFFER
This is how to read the information:
What the wire is
What the wire color is
Wire polarity
Where the wire is located
AUDIO/VIDEO
Battery
ORANGE
RADIO HARNESS
Accessory
BLACK/BLUE
RADIO HARNESS
Ground
BLACK/BLUE
RADIO HARNESS
Amp Turn On
BROWN
RADIO HARNESS
LF Speaker (+)
BLACK
LF Speaker (-)
YELLOW
RF Speaker (+)
WHITE/BLUE
RF Speaker (-)
BLACK/BLUE
LR Speaker (+)
BIOLET
LR Speaker (-)
PINK
RR Speaker (+)
YELLOW
RR Speaker (-)
BLACK
SECURITY
Battery
WHITE/RED OR WHITE/GREEN
IGNITION SWITCH HARNESS
Ignition 1
WHITE
Starter 1
RED/WHITE
All Door Trigger
BLUE
AT BCM MODULE UNDER DRIVERS SIDE OF DASH NEAR KICKPANEL
Domelight Super
BLUE
LF Latch
VIOLET
RF Latch
GRAY
Trunk Trigger
LIGHT BLUE
Parking Lights
TAN
REMOTE START
Battery
Ignition 1
WHITE
Ignition 2
GREEN/ORANGE
Accessory 1
LIGHT BLUE
Starter 1
RED/WHITE
Starter 2
WHITE/BLACK
Anti-Theft Type
UNIVERSAL IMMOBILIZER
Anti-Theft Descript
THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense
BROWN
Neutral Safety
WHITE/GREEN
AT TCM MODULE HIGH IN DRIVERS KICKPANEL NEAR FIREWALL
Tachometer
RED/BLACK
(AC)
AT OBDII CONNECTOR AT BOTTOM EDGE OF DRIVERS SIDE OF DASH TO RIGHT OF STEERING COLUMN
Parking Lights
TAN
Brake Lights
BLUE
AT SWITCH ABOVE PEDAL
Reverse Lights
ORANGE/WHITE OR PINK
IN HARNESS IN DRIVERS KICKPANEL
Horn
BROWN
Anti Theft TX
WHITE/GREEN
(DATA)
IN HARNESS AT IMMOBILIZER CONTROL MODULE NEAR IGNITION SWITCH
CANbus
PINK
(DATA)
Rear Defrost
WHITE
DOOR LOCKS / WINDOWS
Power Unlock
ORANGE/GREEN
PowerLock
GREEN/YELLOW
Driver Mtr Unlock
RED
(REV)
AT MOTOR IN DOOR
Driver Mtr Lock
LIGHT GREEN
(REV)
AT MOTOR IN DOOR
Pas Mtr Unlock
RED
(REV)
AT MOTOR IN DOOR
Pas Mtr Lock
LIGHT GREEN
(REV)
AT MOTOR IN DOOR
LF Window Up
WHITE/BLACK
AT MOTOR IN DOOR
LF Window Dn
LIGHT GREEN
AT MOTOR IN DOOR
RF Window Up
WHITE/BLACK
AT MOTOR IN DOOR
RF Window Dn
LIGHT GREEN
AT MOTOR IN DOOR
CONVENIENCE
Headlights-Lo
WHITE
Headlights-Hi
GREEN
LF Pk Lt Bulb
RED
AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb
WHITE
AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb
RED
AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb
RED
AT REAR RIGHT PARKING LIGHT
All Hazrd Lights
WHITE
AT FLASHER MODULE BEHIND DRIVERS SIDE OF DASH TO LEFT OF GAUGES
LF Hazrd Bulb
WHITE/RED
AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb
GRAY
AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb
YELLOW/GREEN
AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb
WHITE
AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo
BLACK/BLUE
IN HARNESS AT VEHICLE WIPER SWITCH
Wipers-Hi
RED/BLUE
Parking Brake
GRAY
Trnk Release
GREEN
SpeakBeck is offline   Reply With Quote
The Following User Says Thank You to SpeakBeck For This Useful Post:
6spd (10-16-2015)
Old 02-14-2024, 07:59 PM   #2
darkofrs
Drives: 14 frs; drift spec
nice guide, thanks for dumbing it down, the wiring diagrams from oem were too complicated for me to understand
darkofrs is offline   Reply With Quote
Wiring led halos as DRLs Roborat Cosmetic Modification (Interior/Exterior/Lighting) 2 07-17-2012 11:34 PM
FR-S Wiring Detail DIE1000DEATHS Electronics | Audio | NAV | Infotainment 7 07-06-2012 04:57 AM
3rd harness wiring? kndonlee Electronics | Audio | NAV | Infotainment 3 07-01-2012 07:49 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-16-2012 11:41 PM
Wiring Firewall? skoodge Scion FR-S / Toyota 86 GT86 General Forum 3 05-29-2012 03:10 AM
