Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-30-2018, 12:45 AM | #1 |
Drives: '14
Best coilovers for daily driving?
Not tracking or anything. I just want some coilovers that will lower my car about 1.5 - 2 inches. What are the best coilovers under $700 that will help me achieve this?
What are the disadvantages of having cheaper coilovers versus the expensive ones like CSG Tein Flex A's? |
11-30-2018, 08:53 AM | #2 | |
Drives: 2017 BRZ
11-30-2018, 09:28 AM | #3 |
Drives: 2014 Scion FR-S
Tein Flex A, HKS Hipermax, FA500 are all pretty nice.
11-30-2018, 09:33 AM | #4 |
Drives: 2014 Subaru BRZ Sterling Silver
Under $700 coilovers are not worth it.
Disadvantages ------------------- -HORRIBLE ride quality due to cheaper springs. -Cheap coilovers arent made with corrosion resistant materials... since you live in Chicago you get pretty snowy winters. Your coilovers will RUST due to the salt and snow. If you dont drive it in the winter SOME still will rust with rain. -Not the best alignment adjustments. My recommendation for daily driving? The KW V1. Perfect against all those reasons I said before. So save up or put it on a credit card. You will regret the cheaper Teins... http://www.ft86speedfactory.com/kw-v...vers-1001.html Last edited by AutoNewb; 11-30-2018 at 09:52 AM. |
The Following User Says Thank You to AutoNewb For This Useful Post: | kev0 (11-30-2018) |
11-30-2018, 09:33 AM | #5 |
friendly
Drives: 17' 86
I'm going to throw ST coilovers into the mix. They're effectively rebadged KW V1s without the INOX coating from everything that I have read.
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | kev0 (11-30-2018) |
11-30-2018, 09:37 AM | #6 |
You're definitely right. Its a better BANG for the buck if you don't drive in the winter or live in California. They will still rust in the salt and snow. Since the OP lives in Chicago, I wouldn't recommend them unless hes only driving in the summer.
11-30-2018, 10:16 AM | #7 | ||
Drives: '23 BRZ
IMO you're better off buying a set of Swift BRZ Sport springs and keep the stock front upper strut mounts. These springs lowered my car 1.5" front and 1.25" rear. You might cut the bumpstops in half. This should give you close to the desired ride height without destroying the ride while saving you a few hundred $$$. Just do not run camber plates that reduce bump travel with these springs! You will hate the ride over the tiniest bumps if ya do... |
The Following User Says Thank You to ZDan For This Useful Post: | Shark_Bait88 (11-30-2018) |
11-30-2018, 10:16 AM | #8 |
Drives: 2013 Firestorm FR-S
If your only goal is to drop the car, lowering springs on stock or aftermarket shocks will be a much better quality option within that price range. If you're daily driving you don't need the adjustability of coilovers.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
The Following User Says Thank You to Shark_Bait88 For This Useful Post: | lantsalot (11-30-2018) |
11-30-2018, 11:26 AM | #9 |
Drives: 2019 BMW ///M4
Tein Street Basis Z Coilover
http://www.ft86speedfactory.com/tein...l#.XAFkX9tKiUk But I would spend the extra 100 or so and get the Flex Z http://www.ft86speedfactory.com/tein-super-low-flex-z-coilovers-2013-ft86.html#.XAFkmttKiUk'
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
11-30-2018, 11:56 AM | #10 |
There simply isn't many coilovers under $700. Raceland ultimos, Godspeed, Tein basis... just to name a few.
If you are simply going for the low look and don't care about ride quality ^
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
11-30-2018, 12:02 PM | #11 |
Derp
This. If you're not wanting to drop the big money on coilovers and you don't need to adjust, you're probably better off getting springs. I've had a good experience with the TRD springs on stock shocks for about the last 3 years here--can imagine that getting aftermarket shocks would make it a pretty nice ride.
11-30-2018, 12:20 PM | #12 |
Drives: BRZ 2018
Why you search for coilovers for DD, try the Showa tuning evolution that have dual flow valves as Ohlins and are quite comfortable and sport the same time for spirited road driving!
Otherwise something like Cusco touring A adjustable shocks and a set of pink STI or other lowering springs will suit you better. |
11-30-2018, 12:35 PM | #13 | |
The Following User Says Thank You to Tcoat For This Useful Post: | R2 (11-30-2018) |
11-30-2018, 12:38 PM | #14 |
Country Boy 4 Life
After installing coils on my car; I dont think they are "GOOD" for DD. You can DD them, yes no problem. But, Springs are GREAT for DD!
So, there is my $0.02 (I'm running 6th gen FA500s)
I LIKE TIRES! |
Similar Threads | ||||
What Are Your Pet Peeves of Daily Driving (Your FRS/86)? | Little Mt. Fuji | Scion FR-S / Toyota 86 GT86 General Forum | 100 | 11-16-2018 05:16 PM |
Daily Driving/Spirited Driving Brakes | VABeachBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-12-2017 04:11 PM |
Best Tires for Daily Driving Fun | tez2013 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-31-2016 06:11 PM |
Best coilovers for daily driving/durability | Hentai | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 11-24-2015 01:32 PM |
MSSP PSI for daily driving? | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-17-2014 08:49 PM |
