12-29-2018, 11:11 AM | #1 |
Meow
Drives: GT86, Volvo 996
OBD power draw?
Hello everybody,
I just purchased an OBD2 bluetooth dongle, which has an on/off switch on it. Can I be 100% sure that there will not be any power draw at all as long as the switch is on the "off" position? Best regards, Alex |
12-29-2018, 11:31 AM | #2 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I've had my OBDLink MX in two cars It doesn't have an on/off switch per se, but goes into sleep mode when the car is turned off. I've had no problems with it.
The Following User Says Thank You to Qwimby1 For This Useful Post: | alex87f (12-29-2018) |
12-29-2018, 11:53 AM | #3 | |
Drives: 2014 BRZ Limited
You can't be sure of anything, but if it actually has a switch I would expect it to work. What brand/model is this? |
12-29-2018, 02:35 PM | #4 | |
chicken tonight
I wonder if this ties into the mystery of the BRZ battery drainage. Perhaps the waking scanner is not the cause but rather a symptom of unwanted CAN bus activity.
The Following User Says Thank You to Ultramaroon For This Useful Post: | extrashaky (12-29-2018) |
12-29-2018, 04:37 PM | #5 | |
I would prefer a manual toggle. I had looked for one when I bought these, but nobody had one. Now I'm going shopping again. |
The Following User Says Thank You to extrashaky For This Useful Post: | Ultramaroon (12-29-2018) |
12-29-2018, 08:19 PM | #6 | |
Meow
12-30-2018, 11:49 AM | #7 |
I haven't tested it in my FRS, but in my Miata the OBD would come out of sleep mode if I even touched the car, and that was without keyless ignition. I could tell by going in the garage at night. I could see it light up when it activated. For all I know, it might not be sleeping in the FRS because I drive it almost every day.
Tags |
battery, obd, obd2, obdii |
Similar Threads | ||||
Does the Brz/frs/86 still draw attention? | Honghac04 | Scion FR-S / Toyota 86 GT86 General Forum | 115 | 03-02-2017 09:11 PM |
How much extra power can I draw from the fuseboxes? | Achilles | Electronics | Audio | NAV | Infotainment | 6 | 12-16-2014 03:17 AM |
Amp draw | sw20kosh | Electronics | Audio | NAV | Infotainment | 4 | 08-20-2014 01:54 AM |
Draw your BRZ! | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 14 | 09-26-2013 01:34 PM |
Blow through vs draw through MAF | mrk1 | Forced Induction | 9 | 07-24-2013 07:21 AM |
