Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-15-2019, 02:28 AM | #1 |
Drives: GT86
FI 70mm or 76mm exhaust?
hi!
I am building a Stage 3 Turbo GT86 with fully built engine and a GTX30/35 turbo. The goal is 500whp, I'll track the car and get the supporting mods obviously. I am planning to get a full exhaust from Amuse, the R1000. It is 70mm. It is much larger than the stock, but most high power FI guys run 3" (76mm). There is an awesome deal on a used in Europe on the R1000 full titanium exhaust though and LOVE the sound of it! Downpipe will be 3" for sure. Will that be a limiting factor? Does that 6mm matter that much? Another option might be to put an electronic valve somewhere that releases more exhaust on track, but flames under the car are never good, and that would mean more problems... I tried to look for full titanium 3" exhausts but only the Expreme 80S which is a straight piped single exit and I do not like that. Thanks for the suggestions |
02-15-2019, 02:35 AM | #2 |
Drives: 2016 Halo FRS
No, it’s not going to matter. On turbocharged cars, bigger diameter piping is more beneficial the closer it is to the turbo
02-15-2019, 04:14 AM | #3 |
Drives: 2014 GT86
Also if bigger piping is used on catback/axleback side, one has to be ready for sometimes too loud result. For example perrin 3" resonated often mentioned as loud as 2.5" unresonated. +1 for not worth it.
Better think of more robust gearboxes to handle 500whp |
02-16-2019, 09:55 AM | #4 |
Drives: GT86
Thanks!
I think I'll be going with the Amuse then! Yup, gearbox is in the plans as well! That is going to be the hardest part. |
02-16-2019, 12:15 PM | #5 |
Drives: 2017 BRZ w/PP
02-16-2019, 01:41 PM | #6 |
Rust bucket enthusiast
I'm curious, why is the Amuse exhaust your only consideration? Most expensive does not mean the best. Just wanted to float this out here, since $3,000 could go so much further on an FI build than titanium exhaust
02-17-2019, 08:09 AM | #7 |
Drives: GT86
02-17-2019, 08:13 AM | #8 | |
Drives: GT86
I love how the amuse sounds of all, there is a good used one for much less than 3000 and that is the reason I'd go that way. The only thing that would make me choose a different one is if it would be a huge issue performance wise. -5HP loss at 500whp is ok. -100 is obviously not |
The Following User Says Thank You to Levente For This Useful Post: | DarkPira7e (02-17-2019) |
Tags |
amuse, backpressure, exhaust, forced induction |
Similar Threads | ||||
(Used)Powerhouse Amuse R1 Titan Full Exhaust | Trojan_SC | Engine, Exhaust, Bolt-Ons | 14 | 02-08-2019 05:16 PM |
Review on Evasive Motorsport 70mm exhaust | Pekingduck | Engine, Exhaust, Transmission | 3 | 02-16-2016 10:18 AM |
T1R 70mm exhaust Single/Dual | k.houan | Want-To-Buy Requests | 0 | 04-22-2015 09:39 PM |
T1r 70mm exhaust single or dual | Jhon19lopez | Want-To-Buy Requests | 1 | 09-06-2013 08:47 AM |
FRS / BRZ PTS 70mm Catback Exhaust System | DTMAUTOBODY | Engine, Exhaust, Bolt-Ons | 1 | 08-08-2013 02:20 PM |
