Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-23-2011, 06:31 PM | #1 |
Turbo Mafia Presidente
Drives: U Mad?
FB series slant connecting rod. What do you think?
I've read countless posts in this sub-forum. Not many have touched on this design much. FB originally designed to allow compactness for the Forester and Impreza and more stroke for more torque down low.
I want to know what you think about the idea of this sports car having a high output, high revving, n/a engine that may need to rev high to make power with the bigger stroke, smaller bore and what looks like skinny slant connect rods. Are they titanium? Are they at least forged? I have a feeling owners running at the track and autox will blow them up. Although I just don't see a company making a sports car that can't withstand the punishment it knows it's going to receive and what's it built for. On an engine only producing 148hp used for daily driven task by normal people seems good, but for enthusiast level ownership? What do you think? http://blog.edoperformance.com/tag/subaru-fb20/ I know there is an engine spec thread and head specific thread, but I want this to be about the slant connecting rods and how they would fair against high rpm or boost with the big stroke and small bore setup.. |
05-23-2011, 06:42 PM | #2 | |
Drives: Toyota Corolla SR5
05-23-2011, 06:58 PM | #3 |
GL 86!
Drives: Maybe FR-S... maybe not
From what I remember on the subject the slant helps with the forces on the connecting rod bottom end by positioning the connecting rod bolts/cap-screws at an angle the vertical forces won't cause as much stretch between the cap and the rod.
Not 100% sure on it, I can't recall any of the other benefits. I believe the FB rods are cast like most cheap mass produced engine connection rods, they sure as hell wouldn't be titanium, I don't expect titanium components for the stock FT-86 or even STI engine. Forged would be my hope at the moment. Creating a high revving reliable engine is no easy feat. In layman's terms: Decrease inertia via weight and stroke, reduce friction, increase air flow into combustion chamber. |
05-23-2011, 07:15 PM | #4 |
Drives: 2010 Evo X MR-T
the engine is going to be a reworked FB20. this is the only logical answer. i doubt they will mess with the bore x stroke that much. imo you can pretty much kiss an oversquare design goodbye at this point. they will use the D4-S system for a broader tq curve. they will rely on high compression, made possible by direct injection, not high revs to make power. the 200 hp figure thrown around by the press is a good figure.
dont expect a high revving engine. i just cant see them going this route... remember subaru is the one who gave us the EJ25 sti while japan and europe enjoyed the EJ20.... |
05-23-2011, 08:14 PM | #5 |
Drives: '06 AM V8V Coupe
But I thought they SAID it would be high-revving at some point, no?
Either way we just need to wait. |
05-23-2011, 08:33 PM | #6 |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
^ They said it would be 'free-revving' which generally means low internal friction/weight, so you have more control over the engine (much like changing out a flywheel to a lighter one)
05-23-2011, 11:32 PM | #7 |
Drives: FRS :D
I cant see the FB20 getting into Yamaha's hands and not be nice and high revving tho
05-24-2011, 09:27 AM | #8 |
Hot Dog
Drives: quicker than arghx7
I think the OP is a bit baseless in his fears. What draws you to the conclusion they'll fail? The con-rods would obviously have been FEA'd prior to getting out of the concept stage to withstand forces much greater than any driver can impose on them in stock power output. Engine manufacturers subject the engines to marathon WOT/Redline sessions for days at a time, subjecting the engine to stresses and temperatures far beyond it would ever see even at 24 Hours of Le Mans. They're likely forged steel, though that's just an educated guess based on prior Subie engines. Subaru's press releases have stated the slant shape is primarily to quicken assembly and maintenance of the engine. It's a way to save money without sacrificing strength.
Now, you want to talk about aftermarket boosted and/or high-RPM setups? That's another story. The con-rods will have limits, like any other con-rod, but that limit will have to be found.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
05-24-2011, 10:05 AM | #9 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
the reason they're using a slant connecting rod is so you can install the piston/rod assembly after the block halves are bolted together around the crankshaft. on EJ series engines, you bolt the rods (without pistons) onto the crankshaft, then bolt the block together around the crank & rods, and then you install the pistons onto the rods.
with the slant rods, the FB goes together similar to a "normal" engine.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
05-24-2011, 05:43 PM | #10 |
Kuruma Otaku
I thought it had to do with clearance issues, as the halves were kind of offset or something so they could make it narrower with it's new, much longer, 90mm stroke.
Because titanium. |
05-24-2011, 07:26 PM | #11 |
2.1L 3SGTE
looks like it's for both reasons. http://www.caranddriver.com/news/car...-four-car_news
05-28-2011, 07:14 AM | #12 |
Lurks 'n stuff
Drives: 1994 Mazda Miata
And just because the engine is likely to be undersquare doesn't mean it won't be high revving: the 2zz, B18, K24, and the Lambo/Audi V10 are all undersquare.
05-28-2011, 01:00 PM | #13 | |
Drives: N/A
And we know it's capable of 225BHP(230PS). If we're lucky it will be as simple as raising the rev limit and tuning for the high RPM range to get all of the brake horse power. But depending on how much design they put into it, anymore than that is guesswork at this point . |
05-28-2011, 05:04 PM | #14 |
MODERATOR-SAMA
Drives: Swagtron Scooter
If Toyobaru is keeping the slant rods design on the FB20/FB25 for high performance operation, i think it would be kind of a duh to assume that they will be Forged. Over the cast slant rods of the normal FB engines found in the Forester and future N/A Subaru models.
Similar Threads | ||||
Any yanks fans here?? Or anyone following other playoff series? | JDMinc | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 05-14-2020 07:49 AM |
Maybe a back up plan...Official conformation 1 series M coupe. | Shevon | Other Vehicles & General Automotive Discussions | 4 | 07-09-2010 11:31 PM |
AEM EMS series 2 | NESW20 | Other Vehicles & General Automotive Discussions | 6 | 04-22-2010 08:33 PM |
