Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
04-18-2019, 09:24 PM | #1 |
Drives: WRB Subaru BRZ Limited 6MT
Caliper guide pin rubber sleeve
Hi all - I rarely post but I figured this was too good to pass up given the relative lack of information available about this particular issue on the internet.
The brakes on this car use asymmetrical caliper guide pins. The lower guide pin for each caliper has a rubber sleeve (in addition to the accordion-style boot that retains the grease) that sits in a groove along the lower aspect of the pin (fully retained within the caliper bracket bore). The red arrow points to this rubber sleeve on this Subaru parts fiche diagram I edited and attached. Despite the caliper guide pins moving well in their bores, it turns out that even the most minor swelling of this boot is catastrophic. This swelling can be impossible to see with the naked eye (as was the case for me) and can variably allow the guide pin to be reinserted into the bore without issue. Indeed, the left and right sleeves on the two lower pins on my front brakes appeared identical, but my right sleeve variably wouldn't re-insert into either bore while my left did. This was true before cleaning, after cleaning, and after greasing with a high-temp silicone grease. This sleeve, if left untouched, can cause the caliper guide pins to fail to fully re-seat after piston compression, essentially binding the guide pins and causing the brakes to drag. What is so annoying about this is that the pins will still move freely and the loss of pin travel in the bore is so minor it a) doesn't affect replacing the caliper on the bracket or aligning the rotor and pads within the assembly and b) can even still allow the wheel to spin relatively freely after reassembly. This makes it really hard to diagnose as there are many more obvious and common issues to consider, including a stuck/misaligned caliper piston, faulty replacement parts (e.g. warped rotor surface, unevenly milled rotor hat, brake pad misalignment, and even brake hose failure). This rubber sleeve, according to a 2007 patent filing (see: https://patents.google.com/patent/US20080093181 ), has three purported design goals. As speculated in various forums and blogs (see: https://forums.anandtech.com/threads...his-is.259493/ and https://blog.1aauto.com/what-does-th...t-actually-do/ ), the primary goal is to reduce caliper vibration, presumably by dampening the rate of return along the guide pin and/or compensating for upper guide pin wear. The secondary/tertiary goals as described in the patent filing are to possibly improve guide pin alignment/centering and even improve lubricant distribution, although it is unclear in my brief search if there is actually any data behind these claims. Anyway, I wanted to provide a sample size of one (1) to state that removing these sleeves doesn't appear to degrade brake performance in any noticeable way. I did apply a little extra grease in order to compensate for the loss of volume after sleeve removal. I'll update if I notice any issues, including increased noise or wear. Hope this helps some of you if and when you encounter overheating calipers with no readily apparent cause. |
The Following 7 Users Say Thank You to theadmiral976 For This Useful Post: | bcj (04-19-2019), chipmunk (05-01-2019), gravitylover (05-01-2019), Pat (05-01-2019), redwood9d (05-04-2024), soundman98 (04-19-2019), tobin (05-01-2019) |
04-18-2019, 10:12 PM | #2 |
chicken tonight
They keep the pins from seizing.
04-18-2019, 10:59 PM | #3 |
I could definitely see how that could work that but why wouldn't they be used on all the pins? The "top" pin in each bracket is honed to the bore diameter and then a strip of metal is milled off in two places presumably to allow better flow of grease and possibly reduce the likelihood of seizure. Further, the top pins seem to be made from a carbonized metal of some form that I would imagine has anti-seizure properties. In my particular case, none of my pins was seized across all four calipers; in fact, the pins with rubber sleeves seemed to be moving more slowly and even sticking slightly more than the non-sleeved. I admit I haven't looked up the patents for this particular variant of guide pin nor do I have any professional expertise in this field. Mostly just curious and definitely wanted to share this with others since I spent a couple hours trying to sort this out myself this week. |
The Following User Says Thank You to theadmiral976 For This Useful Post: | Ultramaroon (04-18-2019) |
04-18-2019, 11:09 PM | #4 | |
chicken tonight
Lube it. Leave it. If it's damaged, replace it. If it's swollen, hmmm... replace it and make sure the specified grease is used. Will the brakes fail without? I'll pop a fresh bowl of popcorn next year.
04-18-2019, 11:29 PM | #5 |
chicken tonight
I'll do you one better. It's a single-use item.
https://demos.starbase7.net/t3Portal...00CIF02EX.html
The Following User Says Thank You to Ultramaroon For This Useful Post: | theadmiral976 (04-18-2019) |
04-18-2019, 11:50 PM | #6 | |
Looks like they are called bushings as you found in the shop manual which makes sense given how they are positioned in the bracket. I definitely didn't leave off any of the boots - that would be very sad, indeed! I'm hoping they are just there to dampen vibrations and aren't critical for active brake function. At this point with nearly 100k on the car, I could care less if there is ultimately damage in the bore or whatever from not using them. Next time I pull the brakes, I'm replacing most all of the parts and fully rebuilding everything that isn't damaged. Or better yet, I'll just get an AP Racing Sprint kit so I can continue to use my two sets of OEM wheels (one summer, one winter). I probably should have rebuilt the calipers and slide pins this time around but everything was in very good shape and it requires a ton of patience to deal with my dealer and their complete inability to stock anything related to any Subaru other than the Forester and Outback. And I forgot to add rebuild kits into my last online parts order because I'm dumb. |
The Following User Says Thank You to theadmiral976 For This Useful Post: | Ultramaroon (04-19-2019) |
04-19-2019, 12:07 AM | #7 | |
chicken tonight
The top pin takes the majority of the shear load. The bottom one is more of a follower but the damping effect is real. I see your point. It will be interesting to see if there are eventual consequences for omitting them.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | bcj (04-19-2019), theadmiral976 (04-19-2019) |
04-23-2019, 06:20 PM | #8 | |
Drives: MDX, Camry
It is the same way for my 20 year old Toyota and I know as a fact that Toyota sells them separately. So if it is not available for 86, the fault is with Subaru. Toyota is actually very particular with this and for the same car, V6 version got a different bushing from an I4 version.
I also drove 10k+ miles without this bushing and nothing went wrong with it. I installed a new one eventually because I want to. It is very sensitive to the lube we use. I lubed it with CRC caliper pin lube and it swelled. It worked fine with 3M silicon paste. So the bottom line is to stay away from CRC junk. Using a good product from a reputable manufacturer you will be fine. Quote:
The Following 2 Users Say Thank You to qqzj For This Useful Post: | theadmiral976 (04-26-2019), Ultramaroon (04-26-2019) |
04-23-2019, 06:26 PM | #9 | |
Wheels for Brains
A little pricey just for a tube of grease, but man is it a big tube of good grease. |
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post: | gravitylover (05-01-2019), Ultramaroon (04-26-2019) |
04-26-2019, 09:02 PM | #10 | |
Live and learn - I will plan ahead and obtain all of the bushings and boots to properly redo the job when these pads die. |
05-01-2019, 06:00 AM | #11 |
Drives: _
Can it be that the CRC lube is petroleum based hydrocarbons that easily gets ingested into the rubber, while silicone is... silicone, without hydrocarbons?
05-01-2019, 11:37 AM | #12 | |
Drives: MDX, Camry
Sent from my Pixel 3 XL using Tapatalk |
05-01-2019, 01:58 PM | #13 | |
Drives: frs
Did a quick search, and petroleum is a main solvent for *natural rubber. |
05-01-2019, 02:06 PM | #14 |
chicken tonight
Per the service manual, lithium soap base glycol grease is specified.
Tags |
caliper guide pin, maintenance, oem brakes, rubber boot, rubber sleeve |
Similar Threads | ||||
Airlift Rear Sleeve Specs | NeedsBoostt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-23-2018 02:19 PM |
Stuck coilover sleeve. | Phothiraj | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 03-05-2017 01:23 PM |
WTB: Radio Bezel, OEM Auto Shift knob, OEM hand brake sleeve, OEM stereo | Izzy | Want-To-Buy Requests | 2 | 05-14-2015 09:01 PM |
Shifter bushing sleeve/bolt tolerance | supramkivtt2jz | Engine, Exhaust, Transmission | 1 | 03-05-2014 11:53 PM |
STI rubber lip rubber extension and spoiler rubber extension | KSpider | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-21-2013 05:48 PM |
