Old 05-02-2019, 02:20 PM   #1
pwarnick
Drives: 2018 BRZ (Sport Tech RS)
Stock Brembo's not working in the rain
Back in November I bought a 2018 BRZ (new) that came stock with Brembo's (SportTech RS). I've been having trouble when trying to stop on the highway if conditions are wet. Basically, if I drive for a while in the rain or snow (about 10 minutes plus) without using the brakes, then, when I do press the pedal braking is significantly reduced. Meaning, it takes much longer to stop then normal. I'd describe the feeling as if the rotors are covered in oil so that the pads are smoothly slipping and not applying as much force as normal. After applying the brakes a few times it's almost as if they've been cleaned off and braking returns to normal.
For further reading on the issue:
I've taken the vehicle into the dealership a number of times now. They've confirmed there's no leaks in the system, the brakes are visibly in perfect condition and this is not an issue with the tires.
Yesterday Subaru Canada called me suggesting that this may be a problem with ALL Brembo setups on the BRZ. Leaning towards the idea that these are performance racing rotors and not necessarily designed for driving in the rain for a long period without braking.
I'm a little skeptical here and not entirely certain on how to proceed. Has anyone else experienced anything similar to this?
pwarnick is offline   Reply With Quote
Old 05-02-2019, 02:33 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
https://www.ft86club.com/forums/showthread.php?t=133236
Yes, There have been other threads about this....
I LIKE TIRES!
Old 05-02-2019, 02:38 PM   #3
pwarnick
Thanks^^ still trying to figure out the forum. I tried searching but couldn't find anything related.
Old 05-02-2019, 02:40 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Google is the best search tool. Type what you are looking for and add "Ft86club" , then you should have better luck searching.
I LIKE TIRES!
Old 05-02-2019, 02:45 PM   #5
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
2017 BRZ Performance Pack (basically same as SportTech RS) here. I noticed this same behavior with my Brembo's as well. Same circumstances too. Drive 10+ minutes without using the brakes and they seem to go away, then return after you've used them.
I've found it only to be an issue in the cold however. Any snow/rain under 30 degrees and it would occur...not every time, but often enough. It hasn't returned since it warmed up around here though, even when it rains.
I would describe it almost as if the brake booster stopped working. Like I had to really hammer down on the pedal to get it to slow down. Kind of scary when you're getting off the highway and suddenly your brakes aren't there.
Is it possible the discs ice up? Maybe the brake fluid isn't great in the cold? I'm not sure why it does it. But I've kind of stopped worrying about it since it warmed up. I'll be following what you find
MotoX16 is offline   Reply With Quote
Old 05-02-2019, 02:53 PM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Scary shit..
Old 05-02-2019, 03:08 PM   #7
pwarnick
Yeah the more I look into this the more I'm finding others having the same situation with the PP. Originally I was considering it to be a cold weather situation but I was driving in 10 degrees (C) temperatures and it still ended happening frequently. Hopefully once it gets really warm here it won't be as noticeable. The dealer suggested switching out the brake booster vacuum hose but they decided not to because apparently if there was a leak, it would be noticeable at all times (and not just in the rain).
Old 05-02-2019, 03:18 PM   #8
MotoX16
MotoX16's Avatar
Yeah I mean I cant say for sure its only a cold weather thing that's just my experience so far.
That other thread was a good read. It's nice knowing I'm not the only one with this issue but I didn't see any real solutions there.
I'll be keeping my eyes peeled
Old 05-02-2019, 03:36 PM   #9
pwarnick
This is another thread with the same issue:
http://www.ft86club.com/forums/showthread.php?t=125666
The solution as of now seems to be to swap out the pads
Old 05-02-2019, 04:32 PM   #10
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I've experienced this on an older bmw i used to own. It was 100% caused by the brake pads I was running. Some crappy hawks at the time. Switched them out for something else [sorry can't remember the brand] and it was fine.
But I'll take them off your hand .. for scientific research purposes, in exchange for some nice stock brakes.
Jesse36m3 is offline   Reply With Quote
Old 05-02-2019, 04:54 PM   #11
pwarnick
Ahaha, yeah I'm definitely going to swap out the pads. And I'd actually take you up on that but the plan right now is to keep this set for track days
Old 05-02-2019, 06:18 PM   #12
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I have this same issue with my AP Racing BBK. It's always a bit of a butt-clencher when you are on the highway in the rain, and go to use the brakes, and not much of anything happens for that first second-or-so. I'm running APF404 pads, which are apparently almost identical to Ferodo DS2500s.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-02-2019, 07:03 PM   #13
86MLR
86MLR's Avatar
My 2 cents
Street pads for the street and autocross (low dust, kind to rotors)
Track pads for the track (squealing rotor eaters)
Whilst high temp pads are required for the track, they are a definite hazard on the street.
You WILL lose stopping difference between the 2 when cold.
I use to just swap them out prior to the first session.
Easy peasy lemon squeezy
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 05-02-2019, 07:26 PM   #14
kch
Senior Misanthrope
kch's Avatar
Originally Posted by 86MLR View Post
My 2 cents
The problem is people are having this cold-bite issue with the OEM pads.
OP, everything I've read sounds 100% like the pads are either not bedded properly or (more likely) under temperature. I don't know how to fix this, besides either (1) riding the brakes a little (terrible solution); or (2) getting a more daily-friendly brake pad. I'm not sure what the OEM pads are on the PP, but if they come with a "hybrid" type pad like a DS2500, then you should ditch those and get some basic ceramics for street use.
brakes
Stock '18 PP BRZ at Grattan in the rain atomicalex Tracking / Autocross / HPDE / Drifting 22 10-29-2018 04:04 PM
New Here! Tracking with Old Stock Tires (in the rain, first time)? Zycle Tracking / Autocross / HPDE / Drifting 17 10-23-2018 04:29 PM
Stock radio stopped working? Shaun Perry Northern California 2 10-01-2014 01:55 AM
Green Brembo Brake Calipers, and Stock Springs Sivtec Brakes, Suspension, Chassis 23 11-25-2013 10:20 AM
Passenger window not working after rain reset does nothing Mike86 Issues | Warranty | Recalls / TSB 0 08-30-2013 08:18 PM
