DIY (Do-It-Yourself) Guides For all DIYs. |
06-05-2019, 11:52 PM | #1 |
chicken tonight
How I support the engine with a tie-down strap when removing the transmission
A few things to keep in mind.
06-06-2019, 12:03 AM | #2 |
ProCrastinationConsultant
How often does this really need to be done?
06-06-2019, 12:08 AM | #3 |
chicken tonight
Whenever the transmission is removed. Guess I should've explained that.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (06-06-2019) |
06-06-2019, 12:22 AM | #4 |
I just assumed it was an ancient engine yoga technique that allowed for better oil flow.
06-06-2019, 12:33 AM | #5 |
chicken tonight
It balances the engine's chi.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | HaXx (02-21-2020), soundman98 (06-06-2019) |
06-06-2019, 03:08 PM | #6 |
Drives: 2014 FR-S MT
Thanks for the pics. The routing underneath: is it pretty much straight down the sides and then across the oil pan?
06-06-2019, 03:24 PM | #7 |
chicken tonight
Nope. Look for the hooks. You'll slap your forehead when you see it.
06-06-2019, 03:55 PM | #8 |
06-06-2019, 04:00 PM | #9 |
Drives: Crapcan
That looks way more convenient the using a jack.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | H1C (06-06-2019), Ultramaroon (06-06-2019) |
06-06-2019, 06:29 PM | #10 |
chicken tonight
Now you got it.
06-06-2019, 09:20 PM | #11 |
I like this method -- went outside and checked out those steel covers; yes they do seem sturdy enough to hold the engine still via the tie down. Set it once and forget it for the duration of the job. With a jack, it's in the way as you're working and moving back and forth to and from under the car; it's too easy to bump it out of place; and as I learned, also pretty easy to jack it back up too much when replacing a jack that's been bumped out of place. |
06-06-2019, 09:33 PM | #12 |
Drives: Crapcan
...........or when the jack that is supporting the engine is twisted and you can't get the trans jack forward enough to stab the trans into place. Ask me how I know about that one
The Following User Says Thank You to NoHaveMSG For This Useful Post: | korhun (02-21-2020) |
06-06-2019, 10:04 PM | #13 |
[insert cool phrase here]
Drives: BRZ Premium
Been there, done that. I feel your pain.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | korhun (02-21-2020) |
06-06-2019, 10:20 PM | #14 | |
Lol yeah... pulling and replacing the tranny to change the TOB has to be the most unpleasant job I've done on this car. I dented my oil pan by over-jacking the engine after the jack got bumped out of place, and wound up having to replace that. Spent hours trying to cut through the FIPG holding it on. I gave up at one point. Then I got this tool and once it arrived, I was able to cut through the FIPG in a few minutes: https://www.amazon.com/gp/product/B011DR95WM/ And then I had costochondritis for a couple of weeks afterward, from wrestling with a 86 lb hunk of metal for hours, on my back, with about 18 inches of vertical space to move around. Not fun. But, if I have to do it again to fix my small oil leak coming from somewhere in the bell housing, I'll be using this method to keep the engine from tilting forward. |
The Following User Says Thank You to H1C For This Useful Post: | NoHaveMSG (06-07-2019) |
Similar Threads | ||||
Tamara tow strap | Dreyup | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 07-09-2017 04:03 PM |
Takata tow strap | Thatguyjeremy | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-20-2015 09:25 AM |
FS: Takata Tow strap | Tengu | Exterior Parts (Aero, Lighting, Etc.) | 1 | 02-26-2014 08:36 AM |
rear tow strap | karma003 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-23-2013 09:00 PM |
Help me strap down my tires | qoncept | Tracking / Autocross / HPDE / Drifting | 5 | 06-20-2013 04:06 PM |
