Old 09-26-2019, 01:18 AM   #1
qqzj
Drives: MDX, Camry
Performance package wheel/tire weight vs. regular wheel/tire combo
Today I swapped out my old OEM wheels and tires with a new set of OEM performance package wheels and OEM Michelin Primacy HP tires. Both sets have center caps and TPMS. The old tires have about 6/32 inch tread left. The new one seem to have 9.5/32 inch tread. I weighed them with my bathroom scale which might not be as accurate as desired. The end result is that the new set is 42 lbs and the old set is 40.5 lbs. 3.5/32 inch is roughly 2.77 mm. I am not sure whether such a circle of tread can weight 1.5 pounds. Most likely not I guess. So the additional 0.5 inch wheel width does add a bit weight.
qqzj is offline   Reply With Quote
Old 09-26-2019, 01:27 AM   #2
qqzj
Drives: MDX, Camry
To be precise, old OEM wheel is the stock wheels on 2013 BRZ/FRS. 17x7 offset 48. The performance one is the same as
https://www.ft86club.com/forums/show...=114278&page=3
Looks like my bathroom scale did well. From now on, I regard it as industrial class.
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
Wheel and tire combo for 500 hp GrabTheWheel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-01-2018 12:16 PM
Anybody taken their wheel/tire combo off their FR-S and... cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-05-2013 01:47 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 08:33 AM
