Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-25-2019, 02:14 AM | #1 |
Help car not starting!
Alright guys my cars has been down about a month and I'm getting kind of desperate to get it back need some help diagnosing.
So I needed a new clutch bad and decided to do this job myself. (done it before on other cars and after doing lots of research decided I could on this car also while learning lots about my car) The whole process went very well I followed a forums post about the job which helped a lot. One problem was that I connected the battery 2 minutes too early and while tightening a bolt on the starter I had a spark after hitting the trans with the wrench. (huge mistake on my part I know better). After the job the car won't start. I started diagnosing checking all the grounds I touched, going over all my work double triple checking everything and nothing seems off. I can hear the fuel pump turning on and the starter seems to be working fine and the belts all move when cranking but it seems to not be getting spark. I eventually gave it to a shop in hope they could diagnose in more detail and they said my ecu was fried so after getting a brand new ecu and having it professionally programmed it still doesn't start and it's been over a week of them diagnosing since then. I want to mention that my car was on e85 with the oft tuner but besides that no performance/mechanical mods. I thought maybe the new ecu having a stock tune could prevent it from starting with the e85 but the shops seems to think that wouldn't prevent it from starting and that wouldn't explain it not starting in the first place with the old ecu. Any help is appreciated and any questions I'm more than happy to answer! |
10-25-2019, 02:15 AM | #2 |
10-30-2019, 11:18 PM | #3 | |
Drives: Toyota 86 GTS Manual 2015
1) Check that all your fuses are intact 2) Maybe, a new battery? (i assume that the battery was checked for charge already though) |
10-31-2019, 12:52 PM | #4 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The starter is a direct, non fused wire from the battery terminal, it completely sidesteps all electronic components on the car. Jumping it to ground should only result in big sparks.
I suspect the sparking totally threw you if the trail and you're overlooking something basic, most likely human error. You say you've got an oft, can those things display live data? Check your engine rpm while cranking, if it's zero, chances are something happened to the crank sensor or it's reluctant wheel (both are behind the flywheel) while you were in the vicinity. |
10-31-2019, 01:28 PM | #5 |
Check fuses 30 and 45. They are both part of the starter system. A dead short could easily blow one or both.
https://www.autogenius.info/scion-fr...e-box-diagram/
10-31-2019, 03:26 PM | #6 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Has the shop confirmed spark and fuel delivery?
Work Hard. Play Hard.
2016 Oceanic |
10-31-2019, 05:54 PM | #7 |
If your on E85 with stock tune its going to crank fine bit unlikely to start in cold weather as it needs about 50% more fuel delivery at startup.
If you jist replaced clutch im going with guy above its likely the crank sensor or crank wheel installed incorrectly. If so car will crank but wont start as ecu doesnt get a valid crank angle signal. As he said log with oft if you get an rpm reading its likely ok , no rpm reading ie zero then likely crank sensor or wheel insralled incoreectly or sensor bad wiring damaged. It happen a lot when people change clutch |
Tags |
brz, clutch, e85, frs, no start |
Similar Threads | ||||
car not starting | Ayeitsjayson808 | Issues | Warranty | Recalls / TSB | 12 | 04-16-2016 07:21 AM |
starting out | dmitri93 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-11-2014 12:06 AM |
Rev when starting ? (Possible and why ?) | Simon99 | Software Tuning | 11 | 05-22-2014 04:12 AM |
just starting out | mortachi | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-06-2013 10:23 PM |
Starting it off | e10rice | Mid-Atlantic | 93 | 03-26-2012 03:16 PM |
