Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
03-07-2020, 10:13 PM | #1 |
Drives: SWP Subaru BRZ
**HELP** Heated Seats Stopped Working
I removed the connectors so I can take out the heated seat switches to clean them. After wiping them down, I connected everything back (even the cig connector), however my heated seats stopped working. The lights won't turn on, and I tried to see if the seats would work even if the lights wouldn't turn on.
Am I missing anything here guys? Thanks in advance. Im new to this. |
03-07-2020, 10:17 PM | #2 |
ProCrastinationConsultant
first things first, check the fuses in the drivers side footwell.
03-07-2020, 10:22 PM | #3 |
03-07-2020, 10:34 PM | #4 |
Drives: Crapcan
Do you own/know how to use a multimeter?
03-08-2020, 12:09 AM | #5 |
I'll guess you put the connectors back together wrong.
Yep, a multi-meter is a useful tool. Back in the day we had these little store bought test lights. Further back in the day we would make a test light with a 6-V light bulb and two pieces of wire. Before that, we would wear a "car coat" in the wintertime. Racoon coats worked good back in the buggy days. Got to go, it's time fer ma meds - humfrz |
03-08-2020, 04:49 AM | #6 |
helmholtz resonator
Drives: '15 ultramarine
How did you "clean" the switches?
And exactly what lights won't go on? The lights on the switch? If so, I would say you don't have the switches re-connected correctly, or you ruined them. |
03-09-2020, 02:15 AM | #7 |
Drives: 2014 Subaru BRZ (Limited)
I ran into a similar scenario when removing the centre console panel. I didn't disconnect the battery before disconnecting the seat heater and power outlet connections.
as it turns out, I actually blew each lightbulb in the seat heater switches. the switches themselves still worked and still provided heat. I would use a multimeter/voltmeter to check and see if you have heat. Start with the actual fuses though. |
Tags |
heated |
Similar Threads | ||||
Heated Seats not working after Headunit install/ Console Removed | jbsali | Issues | Warranty | Recalls / TSB | 10 | 10-10-2019 10:22 PM |
Heated seats stopped working | macaulay7 | Electronics | Audio | NAV | Infotainment | 9 | 08-28-2018 04:41 PM |
BRZ Heated seats stopped working? | Bd792010 | Electronics | Audio | NAV | Infotainment | 0 | 08-28-2018 04:16 PM |
Key Fob stopped working | SmartedPanda | Electronics | Audio | NAV | Infotainment | 2 | 05-06-2017 01:40 PM |
drl stopped working! help. | blkmamba | Issues | Warranty | Recalls / TSB | 10 | 09-29-2016 06:52 PM |
