DIY (Do-It-Yourself) Guides For all DIYs. |
03-22-2020, 09:43 AM | #1 |
Drives: White GT86
Fitting an aftermarket head unit to my BRZ inc step by step video
Really pleased with the install of the Pioneer SPH-DA130 DAB in my 2013 BRZ. It was super easy to get the stock headunit out and with a little trial and error to get new one in. One thing I noticed is that people are trying to bolt the plastic spacers in between the metal bracket and the headunit, this is incorrect they should go outside the metal side brackets. If you are looking for a helpful video, check out the link below, I am no expert so take this as guidance on how I did it, this isnt the only solution but has worked for me:
The video description also contains all the bits I used to fit it. Thanks for watching, its step by step so around 45 mins long: Untitled by James Baker, on Flickr
https://www.youtube.com/tweedbean - How To Videos https://www.instagram.com/tweedbean - Latest updates |
03-22-2020, 10:12 AM | #2 |
TRACKBREAD
Nice!
I'd recommend the JDM Subaru filler panels, they look much nicer than the aftermarket bits: https://www.ebay.com/itm/BRZ-AV-ESCU...75.c1#viTabs_0 |
03-22-2020, 10:41 AM | #3 | |
Drives: White GT86
03-22-2020, 03:34 PM | #4 |
Drives: 2014 Subaru BRZ (Limited)
not to thread jack but is anyone experiencing issues with their deck losing power upon startup? Mine turns on, then shutdown and then starts up again normally. I've heard its a drop in voltage in the car that causes this and its more common in the push-start models...
03-22-2020, 05:37 PM | #5 | |
ProCrastinationConsultant
The Following User Says Thank You to soundman98 For This Useful Post: | jbsali (03-23-2020) |
Similar Threads | ||||
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
Fitting the radio plug into aftermarket head unit | GC GTS Aero Kit | Electronics | Audio | NAV | Infotainment | 1 | 10-29-2012 05:41 AM |
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
