Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
06-11-2020, 10:21 AM | #1 |
Drives: 2013 Scion FRS (10-Series)
Recommended Tires For 18x8.5 +35 Rims
I'm researching for tires to buy in a month or two for a set of aftermarket rims that I bought online. The rims are AVID.1 AV-06 18" x 8.5" +35 offset concave style. They're going on a 2013 Scion FRS (10-Series) with stock suspension and don't have fender flares at the moment. I've done a bit of research for some tires. I would like to have Toyo tires if possible but I found that Toyo Extensa HP II 245/40R18 would be my first pick. I think these would be the best looking & maximum size I could go. My other alternatives are Bridgestone Potenzas RE980AS 245/40R18 or Driveguard BL 245/40R18 (Most expensive & 50k mile warranty).
What do you guys think? Are these tires a good size & do you think these would look great on the car? Any suggestions are welcome. Thanks |
06-11-2020, 10:30 AM | #2 |
Rust bucket enthusiast
A 245/40 would fit well. 235/45 would also be ok.
Why not look at some other tires? Most of Toyo's non performance tires are rock hard and noisy. The Hankook Ventus v12 concept2 should be cheaper and would be a great all around tire |
06-11-2020, 10:31 AM | #3 |
friendly
Drives: 17' 86
Seems like you're going more for aesthetics than performance so tire choice doesn't matter tbh. You're in florida so zero reason to get an all season other than possibly longer wear at the trade off of shittier grip.
OEM is 215/45/17 235/45-18 would be enormously larger than OEM Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 215/45-17 3.8in 12.3in 24.6in 77.3in 819 0.0% 245/40-18 3.9in 12.9in 25.7in 80.8in 784 4.5% 235/45-18 4.2in 13.2in 26.3in 82.7in 766 6.9% 245/35-18 is close to stock diameter Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 215/45-17 3.8in 12.3in 24.6in 77.3in 819 0.0% 245/35-18 3.4in 12.4in 24.8in 77.8in 815 0.5% https://www.miata.net/garage/tirecalc.html
Seek comfort in discomfort.
06-11-2020, 10:31 AM | #4 |
06-11-2020, 10:40 AM | #5 |
Drives: '23 BRZ
For sure you do not want 245/40-18, that's an inch taller than stock.
245/35-18, or 225/40-18. Would say 235/35-18 are an option but practically nonexistent. Think about what your priorities are for tires. Handling, grip, wet vs. dry, possible snow, max life, etc. Bridgestone Driveguard are "Grand Touring All Season" tires. I.e., very low-performance... Without some negative camber you are going to look quite a bit poked with +35 offset. Definitely would look like a better fit if the car were lowered a bit and with -2 or more negative camber. |
06-11-2020, 10:42 AM | #6 | |
Drives: '23 BRZ
06-11-2020, 10:46 AM | #7 | |
friendly
Drives: 17' 86
I'm guessing pirate glanced over the post and was suggesting sizes for 17s
The Following 2 Users Say Thank You to alphasaur For This Useful Post: | DarkPira7e (06-11-2020), ZDan (06-11-2020) |
06-11-2020, 11:57 AM | #8 | |
A 235/45 I guess may be a bit much. |
06-11-2020, 12:06 PM | #9 |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
06-12-2020, 06:22 PM | #10 | |
pessimistic skeptic
Tags |
aftermarket, frs, scion, tires |
Similar Threads | ||||
FS: OEM tires and rims - Stock rims and tires | Webster10 | Wheels and Tires | 14 | 11-16-2015 05:50 PM |
stock tires with 18x8.75 rims | theflathead | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-13-2015 11:22 AM |
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-18-2013 02:33 PM |
Recommended shop to paint my rims black? | bdanisi | Southern California | 6 | 05-21-2013 01:13 AM |
Recommended Tire Pressure for Aftermarket Wheels and Tires | Chri5 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-15-2013 01:28 PM |
