Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
01-20-2021, 03:07 PM | #1 |
Drives: 2013 scion frs 6 speed manual
Need 4 new tires 2013 frs advice?
I need Tires!!
hey all, havent been on the site in a while My 2013 frs has 63 thousand miles on it and now needs 4 new tires. Before I do so, could any of you advise a good tire and brand? Im in the northeast near NYC . rain ,snow ( but rarely drive in it), and all the rest in dusty dirty bad pot hole part of the USA many thanks doug |
01-20-2021, 03:26 PM | #2 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
01-20-2021, 03:33 PM | #3 | |
Drives: '23 BRZ
For your usage I would stick with either Ultra High Performance All Season or perhaps even High Performance All Season. Go to Tire Rack website and compare tires specifically looking at test results, also customer survey results. Lots of good info there.. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | scionhobokenD (01-20-2021), soundman98 (01-20-2021) |
01-20-2021, 04:14 PM | #4 |
Rust bucket enthusiast
Zdan said it best. Find something that's in your price range and has good reviews.
The plug I typically give is to stick with the Hankook V2 Concept 2 if you want a decent all season tire. I've bounced around on a lot of different tires on a lot of different cars; that tire seems to be the most competent and cost effective for light snow/rain/summer that I've ridden on. I still will advise to never drive an all-season tire on snow if you can avoid it. The reduction in your braking traction is the sole reason why; you really should consider a second set of wheels and dedicated winter tires if you plan on seeing winter/ice conditions based on your demographic. You will thank yourself for the security on that day you need to make an emergency trip in the snow and need to worry a lot less about your traction because you made the executive call to get snow tires. This also lets you beef you your traction in the summer with UHP summer tires that are awesome in the rain and awesome in the dry.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
01-20-2021, 08:21 PM | #5 | |
ProCrastinationConsultant
if you have packed snow, and they sand the roads, not salt, absolutely. but in my area, it snows one day, and it's cleaned up/salted within 6 hours, max. there's absolutely no reason to be running snow tires in my area. all seasons are perfectly fine. i've even tried running snows. they end up wearing out on dry pavement during just the winter season. and half the people in my area are running bald or summer tires in the snow, so the majority of the time, i can stop faster than everyone else anyways.
The Following User Says Thank You to soundman98 For This Useful Post: | Ramster (01-22-2021) |
01-21-2021, 06:27 AM | #6 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
If you don't want to change seasonal tires & want something that you can use all year round, then you may wanna go with the actual 4-seasons called ALL-WEATHER ( unlike "all-season" which is actually just 3-seasons) like NOKIAN WRG4 which perform better than All-seasons especially in the winter
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
01-21-2021, 08:30 PM | #7 |
when did they start making 'all weather' tires? tire rack doesn't even seem to have a category for that...
01-21-2021, 11:11 PM | #8 | |
Senior Citizen Member
https://www.nokiantires.com/tires/pa...weather-tires/ According to Consumer Reports, "All Weather" is a subset of "Performance All-Season". https://www.consumerreports.org/tire...ll-year-round/ In their testing the Michelin CrossClimate + came in first with the Nokian WRG4 at 4th out of 5. What ever. Last edited by LimitedSlip; 01-21-2021 at 11:22 PM. |
01-22-2021, 12:00 AM | #9 |
It's just plain confusing to me.
I bet I could call any tire dealer.. "Hi, I'm looking to purchase a set of all weather tires" "Yessir, we've got a number of all season tires in stock, what car are these for?" "No no, I need ALL WEATHER tires. I was told they're better than all season tires" "I can assure you sir, our all season tires do work in all weather conditions".......
The Following User Says Thank You to soundman98 For This Useful Post: | LimitedSlip (01-22-2021) |
01-22-2021, 03:57 AM | #10 | |
FT8Syg
Apparently, different tires are developed depending on the market: North American, Nordic, & Central European. This summarizes the difference between all-season (usually has M+S & no 3 mt-peak-snow flake symbol on widewall) , all-weather (w/ 3-mt peak snow flake), & winter tires (w/ 3-mt peak snow flake): https://www.canadadrives.ca/blog/mai...s-winter-tires For more in-depth differences amongst summer, all-season, all-weather, winter, snow tyres, and their sub-categories, checkout www.tyrereviews.co.uk
Tags |
2013 frs, all weather, northeast, tires |
Similar Threads | ||||
Advice | Winter Tires or All Weathers | Canuck | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-20-2020 09:21 PM |
Advice for tires. | Chaldea86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 07-14-2020 05:56 PM |
Used 2013 Advice | fjrocktoy | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 11-09-2017 12:10 PM |
need advice for winter tires!!! | ShowTime_DW | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 06-25-2013 12:57 PM |
Need some advice on tires | Touge86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 05-14-2013 10:21 PM |
