BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
02-28-2021, 11:29 PM | #1 |
Drives: 2019 potential buyer brz
shorter overhangs and lower hood
I much prefer short overhangs and low hood lines. I like the red concept car very much. It is cleaner than the FRS concept, with an S2000-like hood line.
Why didn't they produce that beautiful concept? Did they get caught out by some hood pedestrian crash standard? The sheet metal hood lands above the chassis look added on to me. I mean, if you have such a low engine, shouldn't the car lines reflect that instead of looking like a normal engine installation? Anyway, I'm going to modify mine when I get it later this year to shorter overhangs and a lower hood. Last edited by flyboy2160; 03-01-2021 at 10:32 AM. Reason: grammar |
02-28-2021, 11:33 PM | #2 |
ProCrastinationConsultant
post your progress!
02-28-2021, 11:37 PM | #3 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Don't you just end up with a hard top Miata if you do that?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
03-01-2021, 06:27 AM | #4 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I love both current and 2nd gen 86 silhouette.
03-01-2021, 08:53 AM | #5 | |
The Following User Says Thank You to Tcoat For This Useful Post: | NoHaveMSG (03-01-2021) |
03-01-2021, 09:45 AM | #6 |
the amount of metal and plastic fab to re-do the front end has got to be about 5 years worth of spare time work.. it's going to be easier to just chop off the front just ahead of the firewall, and build a tube frame with custom sheet metal...
03-01-2021, 09:47 AM | #7 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post: | NoHaveMSG (03-02-2021), soundman98 (03-01-2021) |
03-01-2021, 10:01 AM | #8 |
Senior Citizen Member
Buying one of these will save considerable time and money:
The Following 6 Users Say Thank You to LimitedSlip For This Useful Post: | Ash_89 (03-01-2021), daiheadjai (03-01-2021), Irace86.2.0 (03-09-2021), Ohio Enthusiast (03-01-2021), Red-86 (03-02-2021), soundman98 (03-01-2021) |
03-01-2021, 10:06 AM | #9 |
Drives: Raven Black
I would love to see how OP intends to achieve this without ruining the car, or costing tens of thousands of dollars in sheet metal and bodywork. (I don't think OP understands what would be involved here)
The Following User Says Thank You to CBR600RR For This Useful Post: | soundman98 (03-01-2021) |
03-01-2021, 10:11 AM | #10 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
The twins already have quite short overhangs...way too much work for a rather minimal change from the side view...and good luck making the bumpers look good after smooshing them in.
Top tier professional designers & engineers vs flybo2160...place your bets folks This reminded me of a couple abominations I've come across on the interwebz like this one.. |
03-01-2021, 10:21 AM | #11 | |
Pavement Grey
Dont worry about the cracking and crunching sounds...those'll buff out hopfully when he's reached the desired overhang. And if the bumper falls apart, just 3d print new ones. Its so easy, why havent the car designers thought of this??? |
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post: |
03-01-2021, 10:22 AM | #12 | ||
I kind of wantta see how this goes.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
03-01-2021, 10:48 AM | #13 |
I'm planning on butchering extra front and rear plastic body panels. I'll reuse as many portions that attach to the car as possible to avoid, as much as possible, fit problems. The remaining areas will be fabricated using Rutan's layup over foam technique. I'll foam an oversize glob of foam in place, trim it to shape, then lay up fiberglass over the foam and remaining pieces of the stock parts. The excess foam is then removed. I have the composite fabrication skills to do this.
I'll probably do the same thing with an extra stock hood. If the new car has structure similar to the existing one, it looks like there is open space to shorten the plastic front and rear bumper covers. |
03-01-2021, 01:07 PM | #14 |
I'd argue that the twins have about the same overhangs as the S2000 already.
That being said, if you are able to actually integrate it as smoothly irl as in a quick photoshop, it could look pretty interesting. |
The Following User Says Thank You to Dake For This Useful Post: | HKz (03-01-2021) |
Similar Threads | ||||
IRP Short Shifter (60% shorter) - Install & Review | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 34 | 02-26-2019 09:41 PM |
FI+ shorter final drive | HUNTERANGEL121 | Forced Induction | 38 | 07-24-2017 12:41 AM |
is there a shorter endlink out there? mcs motion control damper | toby714 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-19-2014 07:28 PM |
OEM shorter lightweight battery bracket? | fstlane | Tracking / Autocross / HPDE / Drifting | 1 | 03-08-2014 12:26 PM |
WTB: Shorter exhaust hangers | FrSnake | Want-To-Buy Requests | 0 | 12-30-2013 09:25 PM |
