Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-29-2021, 05:26 AM | #1 |
Sean 86
Drives: 2019 Toyota 86 TRD SE
CV Axle Failure after 8.6K Miles?
I drive a 2019 Toyota 86 TRD SE. I haven't even hit 10k miles but I am already hearing a clunking noise from the back which I assume is the CV joint from the axle because it follows the rhythm of the car speeding up. I do track it at the Nürburgring and have done 6 laps of the north loop and 1 session at the GP track. Is that enough for the axle to break at less thank 9K miles? I'm going to try to have it replaced under warranty but I know that's no guarantee, but maybe German dealerships are different. Anyone else have problems with the axle breaking that early?
06-29-2021, 09:10 AM | #2 |
Mods to suspension?
06-29-2021, 11:56 AM | #3 |
Drives: Scion FR-S 10 Series
I would talk to the guys at Apex as they have a lot of experience with this platform on the ring.
Also which side of the car did the axle fail on? I believe it is the left side where the exhaust comes quite close to the cv boot and has been a known failure point. |
06-29-2021, 03:37 PM | #5 | |
Sean 86
I was going to hit them up and talk to them about their 86. I have lots of questions, especially since they don't run an oil cooler. And I believe right side. I haven't had a chance to get it on a lift yet but the sound appears to be right side but mine is a dual exhaust |
06-29-2021, 07:37 PM | #6 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It follows the rhythm of the car speeding up but does it vary with load? CV axles typically won't behave badly when they aren't loaded.
06-30-2021, 07:45 AM | #7 |
LMGTFY
Drives: 13 FRS, 91 Miata
Hit any curbs at the track particualry hard?
Any off track excusions? |
06-30-2021, 09:02 AM | #8 |
Sean 86
06-30-2021, 09:04 AM | #9 |
Sean 86
The Following User Says Thank You to Sean 86 For This Useful Post: | x808drifter (06-30-2021) |
06-30-2021, 11:08 AM | #10 |
Drives: Crapcan
Pretty strange to loose a CV that quickly. I have over 90K miles on my car, tons of track days, very low on coilovers. I just replaced my original CV's, but they didn't need swapped.
06-30-2021, 12:51 PM | #11 |
Tags |
axle, cv joint, track, warranty |
Similar Threads | ||||
CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
Headlight Failure | FRSNewb | Issues | Warranty | Recalls / TSB | 9 | 06-04-2015 09:39 PM |
Engine failure - 38,000 miles | Mr 286 | Issues | Warranty | Recalls / TSB | 217 | 10-05-2014 09:52 PM |
DI Failure Issue | Taber | Issues | Warranty | Recalls / TSB | 123 | 07-19-2013 05:20 PM |
