Old 09-06-2021, 12:54 AM   #1
BRZSer
BRZSer's Avatar
Drives: 2013 Subaru BRZ
JDL UEL & Ultimate Racing Turbo Kits, Oil Cooler, Overpipe, AFR Gauge, Oil Cap
Hey everyone! Selling the parts listed below.
Located in Fresno, CA. Willing to ship if buyer pays shipping and PayPal fees. Also, able to drive a reasonable distance within California. Feel free to pm for questions or any other info!
JDL UEL Turbo Kit GT2860rs No Cut Option- $3,000
Used for around 8k miles. ***Will need Oil-pan***
Notable features are:
Unequal length turbo manifold
Garrett GT2860rs turbo, water, and oil cooled.
It comes with a PTP turbo blanket.
Open dump 7psi Turbosmart 38mm wastegate
Turbosmart 38mm Vee Port PRO BOV
It comes with a MAP sensor
Crash beam no-cut option
2.5" downpipe flange
Cerakote heat coated intercooler
Recommended parts list:
Turbo to header gasket (T3)
Down Pipe to Turbo Gasket (210218)
Turbo oil gasket
Coolant lines 3/8" (10mm)
Oil Pan
Oil pan black RTV sealer
BOV Vacuum Hose 3/16"
Wastegate Vacuum Hose 1/4"
Turbo Air filter K&N (Ru-3120)
Ultimate Racing Turbo Kit - $2,450
Used for around 10k miles. Uses and attaches to your own supplied OEM, UEL, or EL header (exhaust manifold). This kit also replaces the over pipe and front pipe!
Garrett T3/T04E capable up to 450 WHP
Catless downpipe
Wideband bung plug
Tial Q-BOV
Open dump wastegate (rated at 7 psi)
Polished charge pipes
Includes Battery kit Includes Map Sensor
New gaskets
New bolts
Heat wraps
Mishimoto Oil Cooler Kit - $350
Used for around 8k miles. I’ve lost the bracket; this was mounted via bolts on the bottom of the plastic bumper cover. Some portion of the fins in the back are bent but oil cooler has no punctures or leaks.
Innovate PSB-1 Boost/Wideband Sensor - $275
Comes with everything pictured along with the gauge pod converter and AC vent.
Motive Concepts Over pipe - $175
Will give you an extra 1-3whp, which can probably make a difference when racing, the more horses, the better.
TRD Oil Filler Cap - $125
Replaces yellow oil filler cap with metal TRD piece. Minor scuffing and imperfections.
A Pillar Gauge Pods with Two Slots - $ 50
Pictures:
BRZSer is offline   Reply With Quote
Old 09-06-2021, 12:38 PM   #2
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
Im interested in the a pillar dble gauge pods. Shipped to 15225?
Pgh_Area is offline   Reply With Quote
Old 09-06-2021, 07:47 PM   #3
BRZSer
BRZSer's Avatar
Should be less than $20 to ship it to you.
Old 01-05-2023, 11:35 PM   #4
STUNNAFC
Drives: 2015 Scion FRS
still available?
STUNNAFC is offline   Reply With Quote
innovate, jdl, mishimoto oilcooler, trd, ultimate racing
Ultimate Racing Overpipe & Downpipe jonbatz01 Engine, Exhaust, Transmission 16 10-31-2016 12:44 PM
Ultimate racing turbo kit brzy007 Forced Induction 49 12-17-2015 10:31 PM
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Poll: Oil cooler kits with oil fed turbo kit sw20kosh Forced Induction 0 07-27-2014 11:19 AM
