Old 10-21-2021, 08:10 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Electric Power Steering with no CAN
Does anyone know if you our EPS motor will run in limp mode with only power and no CAN connection? Context is this is a aftermarket ECU and I'm building the chassis harness and would rather not run add the complexity of steering angle sensor, so just want to give the EPS motor/controller 12v and be done.
Old 10-22-2021, 02:15 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
I read in another thread (I don't remember which) that it does similar to the Prius, but I cannot confirm at the moment. Although, I did recently acquire the parts to experiment with, but haven't done so yet.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
ML (10-22-2021)
Old 10-22-2021, 02:22 PM   #3
ML
ML's Avatar
That is very much what I'm hoping and is my guess just based on visual similarities between ours and the Prius'.
Old 10-22-2021, 11:25 PM   #4
pope
has a funny hat
I found a fail safe chart in the service manual this evening. I highlighted the condition I believe it will operate in when missing the CAN data (speed) from the stability computer. We should have a continuous output roughly equivalent to highway speeds.
ML (10-23-2021)
Old 10-23-2021, 08:06 AM   #5
ML
ML's Avatar
Wow you are awesome! Send me your PayPal and I’ll throw you some beer money!
Old 10-23-2021, 10:43 AM   #6
pope
has a funny hat
Not necessary. I was going through the manual looking for a wiring diagram and stumbled on the chart.
Old 03-10-2023, 06:14 AM   #7
Franklin.
Drives: 2013 Brz Limited
Were you able to find a remedy to this? I swapped in a 2JZ and want to run as much of the car as possible on the standalone ecu.
If there's a way to permanently limit the power steering without the body control & power steering modules id love to hear how if worked out in your case.
Franklin. is offline   Reply With Quote
Old 03-10-2023, 08:41 AM   #8
ML
ML's Avatar
yes, you just give the PS box 12v straight from the battery and ground with the 4ga wire, and then switched 12v to the box on pin 6 of connector a15 to switch it on. it will go on limp mode but I have found it to be perfectly adequate that way
The Following User Says Thank You to ML For This Useful Post:
bcj (03-10-2023)
Old 03-12-2023, 12:51 AM   #9
Franklin.
That makes sense.
Does the power steering box need the other modules in place to have the ability to go into limp mode?
I deleted ABS, and I'm not sure if the box needs inputs from the wheel speed sensors or if I can delete the system all together.
Old 03-12-2023, 12:51 PM   #10
ML
ML's Avatar
That makes sense.
no, I have mine in with an engine swap and a standalone ECU and no ABS and its fine.
Electric Power Steering (EPS) noisy RevoG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 144 10-01-2023 03:25 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 05:27 PM
Electric Power Steering oziel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-24-2021 01:06 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
