Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-16-2021, 03:39 AM | #1 |
Drives: Scion FR-S (10 series)
2013 Scion FRS Rotor Questions
Hi all,
I have a 2013 Scion FRS. I need new rotors as I'm just now running out of meat on the rear pads and it looks like I got some pitting damage on the front rotor from (my guess) some rust that developed over the winter. I figured I might as well do all 4 corners in one go and I really want to do this before it gets too cold out. I decided to go with the OEM pads and rotors as they have lasted me a hell of a long time and I mainly DD it right now. I am sitting at 98k miles and have only changed the front pads about 30k miles ago, and honestly, if my front rotors were not damaged, I would only be doing the rears. I have the US-Spec Scion FRS 2013, so I have the rear vented rotors for clarification. from my search I have found that the OEM Toyota part numbers are: Front: SU003-00586 Rear: SU003-10629 but I have found that the Subaru BRZ rotors are considerably cheaper, so I would like to go with those. The problem lies in the part numbers for the BRZ rotors, there are 2 that go with the 2013 Subaru BRZ: Front (2013-2020): 26300SA001 Front (2013-2015): 26300AE071 Rear(2013-2020): 26700AJ010 Rear (2013-2015): 26700FG000 all include the 2013 model year BRZ and all include the "Base" trim and specify non-Brembo. I'm not sure if it is just a case of one part replacing the other number. I looked up pictures of the Toyota SU003-10629 and compared them to the Subaru 26700AJ010 and they look identical down to the "Subaru" printed on the back of the rotor and the "V" at the end of the part name. I just want to make sure I purchase the correct Subaru parts for my Scion. Thanks again |
11-16-2021, 11:55 AM | #2 |
Purist
Drives: 2013 FRS - Hot Lava
This sounds similar to Hyundai and Kia parts problems. They are the same part number, but one brand want twice as much.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
The Following User Says Thank You to Westen86 For This Useful Post: | RedReplicant (11-16-2021) |
11-16-2021, 12:59 PM | #3 |
11-18-2021, 12:24 PM | #4 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Just get a pair of Centric premium blanks and you’re GTG.
Slow is smooth, and smooth is fast
The Following 5 Users Say Thank You to Capt Spaulding For This Useful Post: | NoHaveMSG (11-22-2021), RToyo86 (11-23-2021), the new guy (11-20-2021), treedodger (12-22-2021), x808drifter (11-18-2021) |
11-20-2021, 04:35 PM | #5 |
Yup +2 to this.
2013 Series 10 FRS #553
11-22-2021, 02:52 PM | #6 |
Drives: 2013 Raven FR-S
I'm about due for new rotors too. What's the part numbers for the Centric blanks?
11-23-2021, 02:18 AM | #7 |
Fronts:
https://www.amazon.com/Centric-Parts.../dp/B000IY4A0Y Rears: https://www.ftspeed.com/part/120-470...s-inc-2013-brz
The Following User Says Thank You to jflogerzi For This Useful Post: | smg1138 (11-23-2021) |
Tags |
brakes, rotors |
Similar Threads | ||||
Brake rotor temperature right/left and front/rear comparison questions | HappyMonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 07-07-2017 02:29 PM |
2013 Scion FRS throwing P1262 Code Questions. | TunaNoCrust1984 | Issues | Warranty | Recalls / TSB | 2 | 04-12-2017 04:49 PM |
2013 10-Series Scion FR-S Sell/Trade Questions | Feathergun | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-01-2016 09:12 PM |
Questions before I buy a 2013 FR-S | sk47 | Scion FR-S / Toyota 86 GT86 General Forum | 62 | 10-06-2014 11:49 PM |
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 | AMPLIFIED MOTORSPORT | Engine, Exhaust, Bolt-Ons | 16 | 10-03-2012 08:03 PM |
