BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
12-27-2022, 02:28 PM | #1 |
Drives: 2014 BRZ Limited
Parts no longer available advice
I am looking at a 2014 BRZ Limited... however, it's got about 155K on it. The Clutch was done at around 106k. Thankfully, this car is a timing chain and not belt.
As far as I know, so far, everything is stock thankfully. So, my questions are... What should I be looking for with that kind of mileage as far as long-term issues? Is there anything that is no longer available for this car that could be a potential issue? I learned the hard way with an 84 RX7 a few years ago, A LOT was no longer available to replace. I know this BRZ is going to be only 9 years old, but... have to ask. |
12-27-2022, 03:01 PM | #2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
There's nothing really mechanical that is likely to fail at a certain mileage. In 190k+ miles these are the only age related issues:
1) multiple bushings needing replacement 2) axle was stuck in the hub and I have to replace the entire knuckle now 3) coolant neck was so brittle that it cracked when I took the hose off. replaced with an aftermarket metal one 4) brake calipers needed a rebuild/replacement due to worn seals and pistons sticking You can still get all parts pretty easily, though used engines are getting harder to come by and much more expensive as a result. |
The Following User Says Thank You to finch1750 For This Useful Post: | Tristor (01-03-2023) |
12-27-2022, 03:14 PM | #3 | |
Drives: Subaru BRZ
12-27-2022, 04:14 PM | #4 |
Im dont treat my car super well but i guess its help up fine. the paint hasnt gone to shit though if you put it next to someone who takes care of it im sure you ould notice a difference. Im also from California where so rust isn't an issue. The doors wont stay open at all though, so whatever piece gives those tension could probably benefit from replacement.
The front and rear ends have both been replaced from seperate accidents though lol. |
12-27-2022, 04:16 PM | #5 | |
Good, it doesn't sound like anything unusual fails with this car from the research I've done. I mean... it is Toyota after all (for the most part). Just was a little concerned with the mileage. But, if it was taken care of properly.. should be good. At least I am hoping! |
12-27-2022, 06:13 PM | #6 | |
Drives: 2013 frs base
@WNDSRFER has 240,000 on his car. If you take care of them properly and drive it like someone's Nana, they will last. Last edited by blsfrs; 12-27-2022 at 08:09 PM. |
The Following User Says Thank You to blsfrs For This Useful Post: | MCD73 (12-28-2022) |
12-28-2022, 07:28 AM | #7 |
Drives: FR-S,GTI
Or you can just beat the shit out of it.
Just change your oil from time to time. |
The Following 5 Users Say Thank You to WNDSRFR For This Useful Post: | blsfrs (12-28-2022), Dave-ROR (12-30-2022), pope (01-12-2023), Spuds (12-31-2022), x808drifter (12-30-2022) |
12-28-2022, 01:21 PM | #8 |
You're right. They are well-built though. So far the car I am looking at... seats are crap and the steering wheel is all marked up from someone wearing rings. 2 Projects right there. Still waiting on the mechanical analysis. Just going off pics so far. I know I want to keep it stock, but don't want a giant project on my hands either.
12-28-2022, 03:08 PM | #9 | |
Drives: 2018 Subaru BRZ Limited with PP
The Following User Says Thank You to Dzmitry For This Useful Post: | MCD73 (12-29-2022) |
12-29-2022, 03:04 PM | #10 | |
If you can't find a cheap OEM replacement just go with an aftermarket that lets you keep the airbag still. |
The Following User Says Thank You to finch1750 For This Useful Post: | norcalpb (12-29-2022) |
12-29-2022, 04:19 PM | #11 | |
01-02-2023, 11:54 AM | #12 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
"The doors wont stay open at all though, so whatever piece gives those tension could probably benefit from replacement."
Door checks, which apparently weren't available for a while, are now back. I bought one for $45, 15 minutes work and solved my biggest gripe about the car. If you can't find one they can be shimmed. There's a thread about that you could look up. |
The Following User Says Thank You to Qwimby1 For This Useful Post: | finch1750 (01-03-2023) |
01-03-2023, 03:16 PM | #13 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | finch1750 (01-03-2023) |
01-25-2023, 05:52 PM | #14 | ||
Drives: FRS
The door does not stay open? I would like to fix this, if possible Please advise. |
Similar Threads | ||||
Advice on replacing oxidized parts | Llilith | BRZ First-Gen (2012+) -- General Topics | 8 | 11-02-2022 10:15 AM |
NO LONGER AVAILABLE | kinghurl | Cars for Sale/Trade | 3 | 11-21-2021 11:05 PM |
Need new rotors - advice on correct parts | stayclam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-22-2019 12:54 PM |
no longer available | AllOutApex | Australia Classifieds | 0 | 01-20-2016 08:08 PM |
No longer available | funx | Canada Classifieds | 3 | 10-29-2013 09:10 AM |
