Old 01-11-2023, 12:25 AM   #1
renzs1
Drives: toyota 86 gts 2016
What is the size of the oil pressure sensor fitting?
Hey guys just a quick question, what is the fitting size of the oil pressure sensor on the engine block where you get the oil feed for your turbo? Thanks!
renzs1 is offline   Reply With Quote
Old 01-11-2023, 07:01 AM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
Oil pressure and temp are both 1/8BSPT, or also called 1/8PT.
KillerBMotorsport is offline   Reply With Quote
engine block, oil feed fittings, toyota 86, turbo
Atmospheric Pressure Sensor Cal3000 Forced Induction 7 01-11-2022 11:18 AM
Brake Booster Hose T-Fitting Size? YamahaR86 Forced Induction 0 08-08-2019 01:47 PM
Need to confirm a size not fitting stock suspension. els7x5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-26-2016 11:11 PM
Broken Oil pressure sensor? Dream20b Issues | Warranty | Recalls / TSB 38 01-01-2016 06:02 PM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 03:28 AM
