Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-08-2023, 09:45 PM | #1 |
6/22/12-2/6/24
Vent Backlight Died
Anybody familiar with how to replace the backlight for these?
I don't suspect a fuse because wouldn't all the other center console backlights be out too?
02-09-2023, 03:13 AM | #2 |
LMGTFY
Drives: 13 FRS, 91 Miata
A fuse might and might not be the issue. Don't assume; look.
Also if you are asking doubt you wanna tackle this yourself. Not 100% familiar but if it's like any of the cars I used to own. Remove AC controls. Disassemble. Solder in replacement LED/Light. Reverse steps. |
The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Grady (02-11-2023), Ultramaroon (02-09-2023) |
02-09-2023, 09:39 AM | #3 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I did this on accident once and ended up purchasing a replacement panel on ebay for $40, which was definitely a little overkill. I ended up just shucking that part out of the one I bought and now I have a spare panel.
Search for 85201CA040.
The Following User Says Thank You to gkubed For This Useful Post: | soundman98 (02-09-2023) |
02-09-2023, 09:06 PM | #4 | |
6/22/12-2/6/24
I put in the headunit, soldered wires for the reverse camera, and drilled in a hole next to the plate lights myself.
The Following 2 Users Say Thank You to Bonburner For This Useful Post: | humfrz (02-11-2023), x808drifter (02-10-2023) |
02-11-2023, 02:40 AM | #5 |
The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (02-11-2023) |
02-11-2023, 10:56 AM | #6 | |
02-14-2023, 04:49 PM | #7 | |
Drives: 2017 GT86
The fix is marginally easier than described here though. The backlight for the knob is a neo wedge bulb; no soldering/desoldering necessary. The temperature control uses the same bulb as the vent selector knob, both being Toyota parts. The fan speed control is a Subaru part, and its backlight is from a number of soldered-in LEDs. Those would require solder work to replace, or just replace the entire unit. I think there are variants of the bulb for slightly different illumination colours, but part SU003-02102 covers many (but not all) applications. I don't know the exact difference between this part number and the other bulbs that have been used in this place. When you tear things down deep enough to get to this bulb, the old bulb just twists a quarter turn counter-clockwise and should fall out (possibly needing a little percussive persuasion, but not much). Stick the new bulb in and turn it a quarter turn to lock. You can consider getting an LED replacement for the original incandescent bulb. I believe it's size T4 - just search for T4 neo-wedge (eBay, Amazon, wherever) and see what talks to you. Note that the LEDs are polarized, so there's a 50-50 chance of putting it in backwards and it not lighting up. If this happens, take it out, and reinstall it rotated 180 degrees from before. |
The Following 2 Users Say Thank You to Luns For This Useful Post: | Bonburner (02-14-2023), x808drifter (02-15-2023) |
02-14-2023, 05:10 PM | #8 | |
6/22/12-2/6/24
Based on online parts diagrams, I think I'll just buy a new control switch: SU00302086 - https://parts.toyota.com/p/Scion_201...U00302086.html I believe the wedge bulb you're thinking of is for the air circulation light (which is still working). The lighting of the vent controls seems to be independent somehow. It seems to be a $50 part for the entire switch, which is kind of steep for what it is but this really bothers me so I'll just fix it. Since I'll be tearing out the center console, I think I'll finally do the soft knee pads swap found on +2014 models.
02-14-2023, 06:22 PM | #9 | |
Drives: 2017 GT86
The entire switch will certainly take care of it. But the bulb itself should do just fine. See https://www.ft86club.com/forums/showthread.php?t=8336 In the first post, the OP replaces these bulbs with red LEDs. The backlight for the blue/white/red scale on the temperature control becomes all red with the red LED in place. |
02-14-2023, 07:28 PM | #10 | |
6/22/12-2/6/24
I'm scrolling through the pictures and his posts, it looks like the Vent mode backlight is done by LEDs as well. I'd rather just buy a whole new switch than solder on new LEDs. https://www.ft86club.com/forums/show...&postcount=109 But it seems this person was able do just swap out the bulbs and found success .. so I guess I'll try swapping the bulbs. Thanks for your help, I completely forgot about that thread you shared.
02-14-2023, 07:48 PM | #11 | ||
Drives: 2017 GT86
So I suspect the one bulb you would be replacing, constitutes 2 LEDs in the above post. Quote:
One thing to be aware of with the LED neo-wedge bulbs, I think most tend to throw their light forwards, while the original incandescent lamps had a filament which would throw more sideways to the periphery of the dial. You can see this in the picture in the first post that I'd cited - the central button for the recirc button is much brighter than the icons around the vent control. The same thing is kinda visible with the A/C button being brighter than the temperature scale. If this bothers you, then either stick to the stock incandescent bulb (which ought to last you another 10 years) or you'll have to figure out some better neo-wedge bulb than what's typically sold (I've made my own in the past for other cars). From what I'm sensing of your preferences, I would just go with the stock incandescent bulb rather than a neo-wedge LED. You're welcome! Last edited by Luns; 02-14-2023 at 08:04 PM. |
The Following User Says Thank You to Luns For This Useful Post: | Bonburner (02-15-2023) |
04-29-2023, 10:21 PM | #12 |
6/22/12-2/6/24
Got her lit up again!
The rotary vent assembly was annoying AF to deal with, took a few tries to get the teeth and parts lined up just right after taking it apart lol Thanks a bunch @Luns
Similar Threads | ||||
Backlight of digital cluster | rocknuts | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 10 | 08-08-2022 01:02 PM |
P3 GAUGES VENT INTEGRATED MULTI GAUGE W/ OEM VENT HOUSING | R2RO | Interior Parts (Incl. Lighting) | 4 | 09-09-2020 04:25 PM |
P3CARS (OBD-2 MULTI) Vent Gauge, Pre-Installed in OEM Vent (NIB) - SOLD | R2RO | Interior Parts (Incl. Lighting) | 3 | 07-25-2017 10:29 PM |
P3 P3CARS Vent Gauge (Vent pre-installed) - $400 shipped- SOLD!! | xuimod | Interior Parts (Incl. Lighting) | 1 | 07-19-2017 07:50 PM |
Daytime dash backlight | k0tkmnd | Electronics | Audio | NAV | Infotainment | 1 | 10-18-2013 07:01 PM |
