Old 02-18-2023, 10:05 PM   #1
andee
Drives: 2013 Scion FRS (NA)
Exclamation Progressively louder clunking noise coming from driver side footwell. 2013 Scion FRS
Hey, so when i bought this car back a few months ago, the noise was so small and subtle that it was easily dismissable, and was only audible at very low speeds while going over a bump in the road or a hole. Ive done coilovers, wheel spacers, short throw, CAI, and some cosmetics. After installing the short throw 2 days ago, the noise got consistent and very loud and obnoxious, and i first thought it was a CV joint or shaft, but after some research i figured out theres no cv joints in the front. What part am I looking for? I cannot find out what its called after a lot of research. I thought its called a U-joint but Im not sure.
andee is offline   Reply With Quote
Old 02-19-2023, 10:07 AM   #2
Dake
Dake's Avatar
Does it sound like it's coming through the steering wheel? There's a spacer in the EPS unit (which is down by your feet) that goes bad and creates an annoying clunking rattle. It's not super hard to replace on your own.
Dake is offline   Reply With Quote
Old 02-19-2023, 08:42 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Also check nut on top of coilover is tight and sway bar end links.
driveshaft, frs, u-joint
Clunking/Pinging Noise coming from Front Left Zeno301 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-17-2021 06:34 AM
Front Driver Side Clunking - Already checked the usual suspects PandaSPUR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-24-2018 12:01 PM
Clunking noise coming from the back ft_86 Issues | Warranty | Recalls / TSB 6 03-03-2016 11:30 PM
Need driver side headlight for 2013 scion frs. miller.4311 Want-To-Buy Requests 6 09-04-2015 02:22 PM
Strange pulsating noise driver side footwell TennisHsu Issues | Warranty | Recalls / TSB 11 09-08-2014 11:59 AM
