Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-10-2023, 10:36 PM | #1 |
The Dictater
Drives: '13 Red Scion FRS
Sway bar bushing issue
Hello internet. I feel like I messed something up with my sway bar install. Installed a Perrin 19mm front bar, after having greased the crap out of the inside of the supplied bushings and everything is torqued to spec. But now, before installing endlinks I cannot physically rotate the bar in the bushings.
Yes, I know car forces are way more than my wee little arms can generate, but I was quite easily able to rotate the OEM bar once the end links were disconnected and I wouldn't think this should be 5x or more greater force needed. Any ideas on what could have gone wrong? Is this normal?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
03-11-2023, 02:40 AM | #2 |
Drives: Toyota 86
I have no experience on this brand of bars but I’ve tried all the whiteline ones on both front and rear and they were all the same, when installed the bar cannot rotate as freely as the oem one. This should make the bar stiffer and the solution is using a washer or two to relieve some pressure on the bushing, keeping the holding bracket a tad higher basically.
I did this on my rear 16mm whiteline solid bar and it worked, I haven’t done the same for the front cause I wanted it stiff and solid so it didn’t bother me at all. |
The Following User Says Thank You to marco_mc22 For This Useful Post: | Spuds (03-11-2023) |
03-11-2023, 03:08 AM | #3 |
The Dictater
Upon further research, the search term for this seems to be "sway bar binding". Knowing that leads to finding videos/articles that say shimming with washers is a common solution.
Apparently it should not be difficult at all to rotate the bar.
The Following User Says Thank You to Spuds For This Useful Post: | strat61caster (03-12-2023) |
03-11-2023, 08:09 AM | #4 |
Drives: 2018 BRZ
Interesting that their bushing is so undersized. Might be too late now, but do you know the ID of the bushing? Or is it an issue of the bushing external shape that gets too compressed by the bracket?
I experimented with a Whiteline 14mm rear bushing with the 15mm 2017+ OEM sway bar and it still rotated freely (the bar did bind after a few months, presumably as the grease was forced out). I'm also using Whiteline 18mm front bushings with the OEM bar and it rotates freely. |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Spuds (03-11-2023) |
03-11-2023, 10:47 AM | #5 | |
The Dictater
03-11-2023, 04:36 PM | #6 |
The Dictater
Took a measurement of the Perrin bushings and stock bushings unclamped. The Perrin bushings are about 3mm taller than the stock ones, and being poly probably will compress less than the oen rubber.
This happens to be precisely the thickness of one of the Whiteline endlink heavy duty washers, but I should probably use those on the end links like I'm supposed to lol. Washer hunting I go... ... Found two regular sized washers to shim with that combine to 3mm thickness. I'll see how that goes. Other options include one or two larger washers 2mm thick each. If anyone has had a bad experience with shiming this way, let me know so I don't break stuff?
03-11-2023, 08:23 PM | #7 |
The Dictater
Update: 1.5mm shim on the stud and 3.8mm shim on the bolt seems to have made it better. Still not great.
I think the bar might be too short or warped somehow and that's causing weird angles with the bushing on the curved bits. There's about 1/4 inch of play side to side and at a very specific point the bar rotates easily, though it is inconsistent. Grrr.
03-12-2023, 01:56 AM | #8 |
Likely designed to need some break in, worth emailing Perrin tech support iirc they’re decent.
The Following User Says Thank You to strat61caster For This Useful Post: | Spuds (03-12-2023) |
03-12-2023, 01:52 PM | #9 |
I've had the Perrin 19mm sway bar before but didn't run into this issue. @strat61caster is right the first step is to contact customer support and hopefully get them to send you replacement bushings. You absolutely do want the bar to freely articulate up and down. I personally wouldn't run bar bracket spacers...I think you'll find a way to free up the bar without them.
I don't think it would be a problem installing 20mm bushings if that didn't work out. Also, when you applied ze lube did you lube just the inner portion of the bushing, or did you also do it on the bar itself where the bushing sits? I like to include the bar as a place to lube since grease may be squeezed out of the bushing when slipping it on, especially when the hole is small diameter relative to the whole bushing. |
The Following User Says Thank You to norcalpb For This Useful Post: | Spuds (03-12-2023) |
03-16-2023, 09:44 PM | #10 |
The Dictater
Update on this. After communicating with Perrin technical support, the conclusion is that the bar is within spec but the bushings are too tight and likely out of spec. They are going to send me new bushings. It seems they may have gotten a bad batch so it might take some time.
Other points of note from Perrin support if anyone is troubleshooting a similar issue and finds this: -Bushings should allow for easy actuation of the bar without shimming clamps. -There may be some break-in that normally occurs with the bushings, but it should not be difficult to actuate at first. -1/4" of gap between the bar stops and bushings is within specification. -Bar thickness measured at 19.15mm is within specification -It appears that I did not mess up the installation, but installing the bar upside down has caused strange issues in the past.
The Following 6 Users Say Thank You to Spuds For This Useful Post: | marco_mc22 (03-17-2023), NoHaveMSG (03-16-2023), norcalpb (03-16-2023), Ohio Enthusiast (03-16-2023), strat61caster (03-17-2023), Ultramaroon (03-18-2023) |
04-29-2023, 10:44 PM | #11 |
Drives: 2023 BRZ, 2018 Golf R 6MT
I think my front bar has the same issue. I disconnected the endlinks and the ever present jiggle in my front end disappeared, and the suspension felt like it was working incredibly much better / smoother. I got under the car, and with one hand on each end of the bar and pulling down, I actually lifted my upper body off the creeper before the swaybar rotated.
The bushings definitely fill the bracket way more than the stock ones, and stick out past the surface where it mounts to the car. Is there someone in particlar I should speak with at Perrin? -Mike |
Similar Threads | ||||
Vented sway bar bushing shield | norcalpb | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 03-04-2024 04:21 PM |
Failing Sway Bar Bushing? | jkost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 04-20-2021 04:14 PM |
Rear sway bar bushing | T0rt0r0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 11-10-2018 02:41 AM |
Is this a busted sway arm bushing? | ironsurfer129 | Issues | Warranty | Recalls / TSB | 9 | 08-26-2017 01:09 AM |
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
