Old 03-21-2023, 03:44 PM   #1
JohnGT86-Uk
Drives: 2017 GT 86
Exclamation AEM Wideband 30-0300 Running Full Rich On WOT
Hello Guys
Having some teething issues with my AFR readings
Adrian @ Fensport is mapping my car and now that he is requesting full throttle logs we have realised the AEM Wideband has a big difference in readings between the oem AFR readings - I have attached the log
When driving the car normally the readings are good - Arround 14.7
As soon as you hit boost its almost instantly reads full rich AFR 8.05
I've tried the test where you take the sensor out and it reads full lean and then cover with a rag with brake cleaner and it reads 0.
Car Drives perfectly and he deffiantly doesn't think the cat is running 8 afr WOT - no Black smoke when under load
I've tried the free air calibration thing but it says fail.
I've also seen people unplug the Sensor from the back of the gauge and it normally defaults to 14.7 on the gauge but mine states full rich which is odd
Thanks for reading
JohnGT86-Uk is offline   Reply With Quote
Old 03-21-2023, 10:19 PM   #2
tomm.brz
Drives: brz 2017 hksv2
is the wideband new and fresh installed ?
if yes i wouldn t think it is wrong, and he should probably rescale the front o2 sensor to it
( why do you have a wideband installed? are you FI?)
if it was working before, and now suddenly super rich, it is probably fouled then and no other way than to change it with a new sensor from Aem, those things have short life
but it s probably a dying wideband sensor anyway, my aem 30-300 started to do the same thing, with WOT suddenly at 9.5-10 and then jumping to 20 or leaner in a fraction of seconds
you can also only change the sensor without the whole controller
aem, afr, faulty, issue, turbo
Running rich/OFT issue? Impureclient Software Tuning 6 11-02-2017 05:35 AM
OFT+OFH running rich Dabrown Software Tuning 14 11-28-2016 03:20 PM
OFT STAGE 1 running rich? Flat_4_Life Software Tuning 4 04-21-2015 06:28 PM
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 01:55 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
