Old 03-22-2023, 04:58 PM   #1
softail
Drives: GT86 2013 E85
Tuned cold start and oil dilution
I'm on E85 through OFT and Wayne's ROM. It is accepted that cold start (high rpm, valve timing, ignition retard) is mainly used to warm cats.
To our tunes we take them off because we don't have any more cats and we don't want to wake up our neighbors.
I read in CAR TROTTLE, that the ECU increases engine speed at initial idle to also ensure that all excess fuel is expelled from the cylinders faster than normal.
The dilution of the fuel in the oil takes place during the starting phases. I wonder, and especially for those who are at E85, if it is really relevant to remove the cold start procedure?
Sorry if this topic has been covered before but I couldn't find any real answers.
softail is offline   Reply With Quote
Old 03-22-2023, 05:21 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Removing cold start is just to keep noise down. I have mine still
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-22-2023, 09:05 PM   #3
tomm.brz
Drives: brz 2017 hksv2
cold start in HARD CODED
it means you never get rid of it, you just tame it
still the car will do a stratified injection with very late DI injection and retarded timings
Don t worry about it, nothing bad will happen also with e85..
The Following User Says Thank You to tomm.brz For This Useful Post:
Teseo (03-29-2023)
Why cold start? gpvecchi Software Tuning 16 07-13-2022 07:04 AM
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
