Old 03-26-2023, 08:14 PM   #1
mkoot
Drives: low black brz
Post Boxer engines share same header setup for turbo GT86
Hello I was wondering if there were any Subaru engines that have a similar exhaust setup that I can install a turbo from a used manifold. Will all I need for a entry setup is a turbo, (“idk”WHAT connects directly to it?) BOV filter, the part for intake! Then a down pipe that goes to over pipe. Planning to keep intercooler oem. Does that seem like a “complete” setup that’ll stay running as I add to? I’ll need a tune I assume I have open flash maybe suggest??
mkoot is offline   Reply With Quote
Old 03-26-2023, 08:27 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Yeah I mean all you really need is all the parts you need and bam it's done. Ez
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 03-26-2023, 09:22 PM   #3
Ultramaroon
chicken tonight
Ultramaroon's Avatar
I don't understand why everyone doesn't do it.
Old 03-26-2023, 11:18 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
yep, just need to widen the front frame rails, tweak the hood height and the entire fa20t from the new wrx drops right in.
Old 03-27-2023, 05:18 AM   #5
KillerBMotorsport
KillerBMotorsport's Avatar
The exhaust manifold and J-Pipe on turbo FA engines goes the opposite direction. On an engine stand, easy. In the car, not so much.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
CSG Mike (03-27-2023), soundman98 (03-27-2023)
Old 03-27-2023, 09:33 PM   #6
soundman98
soundman98's Avatar
no problem, just remove the radiator. that's only there for the EPA anyways.
manifold, oft, reliable, setup, turbo
3D Printed Subaru WRX Engine - How Boxer Engines Work phm14 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 05-16-2020 10:43 PM
Boxer Engines Poll JD001 Other Vehicles & General Automotive Discussions 43 06-03-2016 03:29 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
Torque dip common to NA boxer engines? zdr93523 Engine, Exhaust, Transmission 45 04-18-2014 08:35 PM
Boxer Engines and Superchargers brillo Engine, Exhaust, Transmission 2 01-06-2012 05:49 AM
