Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-12-2023, 03:33 PM | #1 |
Drives: 2023 GR86 MT
Opinions on TRD GR Member Brace Set for Gen2?
Has anyone installed and tested the TRD GR Member Brace Set for the 22+ GR86? How does it compare to other braces?
04-14-2023, 11:59 AM | #2 |
I’m curious as well. However, the gen 2 skid plates bolt to the new oem crossmember braces, so going to a gen 1 front brace would require a gen 1 skid plate.
03-04-2024, 12:04 PM | #3 |
Drives: TRD Supercharged 2016 FR-S
I have the TRD Member Brace Set for gen 1 (it is a TRD product with GR branding btw).
There will always be debate on if braces work or not, and this is what I always say. The purpose of it always matters. If it is a DD that never sees events there is zero need and it will make the ride quality worse. If you do HPDEs bracing is generally good. People always say that an upgrade is supposed to lower a lap time exclusively, that is not always true though. These have very good chassis for a reason. The chassis (and the stock bracing) is put in there to keep the car connected and controllable. Put it this way, upgraded/stiffer bushings are put in to control the movement of whatever it is in. A brace is similar in that it prevents movement, but it is different in that it prevents metal from flexing by making other metal compress (metal is strongest when compressing) rather than rubber compressing. I brought up the debate on 'dropping lap times' because bracing itself does not drop lap times individually. I mentioned control, and a big point about control is predictability. if you are able to predict your car better you yourself will be more confident, it prevents mistakes, and it can impact the performance of other important systems (like suspension). The biggest thing is bracing the parts of the car that need it. Putting a brace across a bar (both connection points are on the same bar) does absolutely nothing good and just adds weight. Original 911s are notorious for being unpredictable due to their rear engine layout. Due to various bracing and other systems in the car, it has made the car much more controllable in the current generation. Hopefully a bit of all of that info helps in your decision. with my car with some other bracing it is very predictable on the edge, and have gotten plenty of compliments about it.
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace |
Similar Threads | ||||
Fs: 2nd gen GR member brace kit | Derka | Brakes, Suspension, Chassis | 0 | 06-26-2022 04:58 PM |
HUGE Discount: TRD 86 Member Brace - 1 set only $399.99 | nigel-jdmparts | Brakes, Suspension, Chassis | 5 | 06-26-2017 10:38 PM |
anyone install cusco front member power brace? | three3y3wrbbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-03-2013 12:49 AM |
