Old 04-13-2023, 11:47 AM   #1
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Oil Pan Seal Rings
Pulled my pan to weld on turbo oil drain, installed it and don't seem to have any problems. However, another thread in here made me check the factory service manual, and I found this
I did not install these 2 "oil pan seal rings". What are they for, and do I need to pull the pan again?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 04-13-2023, 12:59 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe you are fine.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DocWalt (04-19-2023), Ultramaroon (07-13-2023)
Old 07-13-2023, 05:29 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I re-used mine since they were not included in the OEM’s re-build gasket kit.
After all, any oil leaking past them just ends up in the oil pan, where it is destined anyway.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. A052 on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-13-2023, 09:40 PM   #4
Ultramaroon
chicken tonight
Ultramaroon's Avatar
Don't underestimate the siphoning action at work. That's the whole point of those drain tubes. They cost money to make and should not be neglected.
Old 07-14-2023, 08:24 AM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
On top of that, imo it isn't worth trashing your engine to save on 10$ of oem parts.
Breadman is offline   Reply With Quote
Old 07-14-2023, 12:02 PM   #6
Ultramaroon
chicken tonight
Yup. I reviewed my post. Not to you, but I may not have adequately described my intent in saying "they cost money."
Nothing is added without good reason. When the purpose of a part, or subsystem in this case, isn't clear to the owner, the correct decision is to assume that it's important.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Hubcentric Rings ry_zillafrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-30-2016 11:09 PM
AEM gauge rings Mike&Ike Want-To-Buy Requests 0 12-02-2014 11:18 PM
HUB Rings - Aluminum 73.1 - 56.1 Jay2420 Canada Classifieds 0 10-16-2014 05:52 PM
