Old 05-23-2023, 01:23 PM   #1
Mont-E
Drives: Scion FR-S
Change gear ratio
Please move if incorrect category
I remember seeing a guide that showed that you can change at what RPM the gears shift from 1 to 2, 2 to 3 etc, in an automatic.
Cannot seem to be able to find it again.
Any suggestions?
Mont-E is offline   Reply With Quote
Old 05-24-2023, 05:39 AM   #2
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Any suggestions?
The year determination tables are only for manual gearbox
The tables do not determine shift points they simply calculate the gear from the spped andcrpm to drive the gear display for manual cars
The auto the shift points are determined by the auto transmission control unit not the engine ECU
AussieBRZ is offline   Reply With Quote
FS Trd close ratio gear set 1-2, mfactory 6th gear AxisPower Transmission and Driveline 10 03-14-2024 09:37 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
Automatic Gear Ratio change Toyota86.ir Engine, Exhaust, Transmission 31 05-10-2016 03:10 AM
4.556 final drive with TRD gear ratio change - good or bad idea? nzer Engine, Exhaust, Transmission 51 12-26-2015 09:15 PM
Gear Ratio Change Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 06-26-2014 10:20 PM
