Old 06-17-2023, 12:16 AM   #1
johnnyeisu
Front brake squeal when coming to a stop with wheel turned
Would appreciate it so much if someone can diagnose wtf this is. I've been trying to solve it for half a year, spending loads on repairs and parts. About ready to just swap the kit out.
The kit is a budget Wilwood 2 piston caliper with slotted rotors package from RR-Racing.
Things I've tried:
Used BP10 and Polymatrix Q compounds, both supposed to be quiet and low brake dust.
Wilwood support has been unhelpful, telling me to center the caliper and buy shims. Caliper is dead center and I bought shims off of them and noise is the same.
Brakes have been freshly bled.
Anti-seize at all contact points.
Things to note:
Like title states, noise is heard when coming to a stop. Usually no noise until brakes are moderately used. It also may occur at low speed corners when the brake is depressed a certain degree. Soft braking and hard braking do not trigger the noise.
Cheers.
johnnyeisu is offline   Reply With Quote
Old 06-17-2023, 04:04 PM   #2
strat61caster
strat61caster's Avatar
How do you bed in the pads?
ineedyourdiddly
Old 06-17-2023, 07:45 PM   #3
johnnyeisu
I've bedded each pad the same way according to the instructions from Wilwood:
A couple warm up stops from 45 to 30 mph, a series of hard stops from 60 to 5 with a few second intervals in between, then finally letting it cool for a few hours.
The Following User Says Thank You to johnnyeisu For This Useful Post:
strat61caster (06-17-2023)
Oil light blinks for 1-2 seconds when coming to a stop/complete stop kev0 Engine, Exhaust, Transmission 27 07-09-2019 11:30 PM
Squeal when leaving a stop Anderzz Engine, Exhaust, Transmission 4 10-29-2018 02:46 PM
Selling: FRS/BRZ Stop tech SS Brake Lines - front + rear bnib $180 Xplicit Canada Classifieds 0 11-25-2016 12:58 PM
FS: CA Front Stop Tech Sport Brake Pads Brand New $50 shattered_memory Brakes, Suspension, Chassis 1 08-11-2016 05:03 AM
Cusco Strut Bar CF (Brake Stop) front and rear FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-20-2014 09:34 AM
