Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-30-2023, 11:50 AM | #1 |
FNG
Drives: 2013 Subaru BRZ
Street Prepared - Build Conversation
I recently converted my car to E85 which took me out of Street Touring. Since running in Xtreme Street doesn't really enthuse me, I'm looking at moving all the way to Street Prepared since the 2013's are now in DSP with full prep.
So, I'm looking for recommendations for suspension setup. Here is what I have now suspension-wise: Shaftworks USA Coilovers - Entry level RacerX Front LCA - not yet installed Whiteline Rear LCA new version - installed but will move to another car Whiteline Rear Toe Links - installed but will move to another car RacerX front and rear end links I'm thinking that replacing the Whiteline stuff with parts with spherical bushings is the right path and a mix of RacerX/Verus/SPL is where I'm headed. I'm also thinking I will probably use the car going forward for Time Trials in Max 4 but that's a stretch objective. Thoughts on any of this stuff from anyone with experience in Street Prepared? |
07-30-2023, 04:04 PM | #2 |
I’ve dabbled in SP-lite, burned up a few A7’s on another car. Wheels and tires are the biggest factor, your build will cater to that, otherwise most of your setup work will be thrown out the window when you finally commit to cutting the fenders and going for the 275-335 wide A7. So that being the case why not skip the sphericals and stay in ESP with limited prep? I’ve got an old set of A7’s 225 on my backup wheels I’m going to try soon, just a straight STX car with old hohos and see how it goes.
Edit: 295/35/17 has a 25.3” diameter probably the biggest you’ll get without getting crazy, 275 is the runner up. Last edited by strat61caster; 07-30-2023 at 10:51 PM. |
07-30-2023, 04:40 PM | #3 | |
FNG
08-02-2023, 11:57 AM | #4 |
Drives: Crapcan
Just FYI. RacerX rear LCA's may not work with the Shaftworks coilovers. I had issues with them with my Annex which have similar bodies to the Shaftworks.
08-02-2023, 12:16 PM | #5 |
FNG
08-03-2023, 11:33 AM | #6 |
Drives: Toyota GT86
How are you liking your coilovers ? I have a set coming myself
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
08-03-2023, 12:55 PM | #7 |
Tolerance issue, I did some sanding on mine to clearance them before going back to stamp steel spc/whiteline lca which have enough ‘squish’ available to make putting them on easy, or at least doable with a prybar. Seeing some experienced SM builds and having those racerx lca’s fail me on the street I’m sticking with the steel for most projects. Probably not a big deal for most people because racecar.
08-03-2023, 02:49 PM | #8 |
FNG
The Following 2 Users Say Thank You to RT-BRZ For This Useful Post: | autoracer86 (08-04-2023), strat61caster (08-03-2023) |
08-04-2023, 07:37 AM | #9 |
Drives: Toyota GT86
Thanks for the feedback
The Following User Says Thank You to autoracer86 For This Useful Post: | RT-BRZ (08-04-2023) |
02-27-2024, 10:23 AM | #10 |
Pawn in game of life
Drives: 19 STX BRZzz
I see Lugod has been dabbling in ESP with his late model 1st gen with good success. 295/15's! Curious what 15" wheel would fit over the front brakes and what steering limiters are needed.
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post: | strat61caster (02-28-2024) |
02-27-2024, 03:31 PM | #11 | |
AutoX-10/10ths every run
I had 295/35/17 square at one point. It's doable, but offsets, camber, and clearance (esp in the front) are going to have to be just right for it to work.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | strat61caster (02-28-2024) |
03-02-2024, 11:34 PM | #12 |
holly shit 295!!! how wide of a wheel?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | whataboutbob (03-03-2024) |
03-03-2024, 12:11 AM | #13 |
lol, 17x9.5, the A7s were a bit pinched
03-04-2024, 09:29 PM | #14 |
a bit pinched? and that was in slicks?
Sent from my Pixel 6 using Tapatalk
Similar Threads | ||||
WTB: Autocross prepared car (STX, SSC, Street) | Optimoose20 | Want-To-Buy Requests | 1 | 08-02-2020 06:44 PM |
Autox: Limited Prep Street Prepared FRZ in DSP | strat61caster | Tracking / Autocross / HPDE / Drifting | 14 | 10-28-2019 01:00 PM |
MyNameIsKeh's Street Build | MyNameIsKeh | Member's Car Journals | 2 | 10-01-2018 12:38 PM |
Street/Rally Build | z3ro | Member's Car Journals | 3 | 06-07-2014 06:21 AM |
What Street Prepared class? | Simmons | Tracking / Autocross / HPDE / Drifting | 6 | 02-25-2013 05:15 PM |
