Old 08-02-2023, 12:56 AM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Arrow BTR Justin - 2022 GR86 journey
Well, I haven't done a build thread in about 15 years, but suddenly got the motivation to do one for my GR86.
Not sure where to start, since I've already had it for almost 1.5 years. Here goes...
Car is used as a DD, as well as autocross (casual, not built to be competitive), and track TT/lapping. TT is also not competitive, as I have a purpose-built TT car for NASA TT4.
Car info:
2022 Toyota GR86
Trueno Blue, 6 MT, Premium
Acquired late March, 2022, after putting deposit down on January 3rd, 2022.
All of my formal videos are on my BTR Garage YouTube channel
All of my raw lapping videos are on my personal channel
Current upgrade and mods list (in rough order of installation):
  • Borla S-Type exhaust (gen1 version)
  • Shaved fenders front and rear (including rear trim piece)
  • Cusco pedal cover
  • Hawk DTC 60 brake pads F/R (for track)
  • ATE Type 200 brake fluid
  • Muteki lug nuts
  • ARP extended studs, 3" F, 2.5" R
  • Muteki 12mm spacers (F/R with OEM wheels, F only with Volk wheels)
  • OEM crash/camber bolts
It's worth noting that I ran the car in the above configuration for nearly the entire first year of ownership. This included about 8 track races (TT5 with NASA) or lapping days, 60+ autocross runs, and several canyon drives. OEM PS4 tires, 5W-20 Mobil 1 syn oil.
Also, I dropped the oil pan and cleaned the oil pickup at 3800 miles (RTV found). I did it again at nearly 8000 miles and found only a few specs of RTV in the pickup.
Mods continued:
  • Eibach Pro Kit lowering springs
  • K&N air filter
  • Grimmspeed intake tube
  • Noble CF hood struts
  • SPC camber bolts
  • Jackson Racing oil cooler
  • Pedders front top hats (static -camber)
  • Cusco strut bar with master cylinder brace
  • SPL rear lower control arms
  • Jackson Racing anti-dive kit
  • CSG brake pads (replaced used DTC 60's)
  • Cusco F/R tow hooks
  • Volk CE28SL 18x9.5 +45, pressed graphite
  • Bridgestone RE71RS 255/35R18 on the Volk's
  • GT Radial SX2 235/45R18 on OEM wheels (after burning up stock PS4's on track)
  • HT Autos front lip kit
  • GJP IO Box and oil pressure sensor for CAN data acquisition
  • Moroso 1.5qt oil accumulator, Canton electronic on/off valve, Ansix auto install kit (hose, fittings, mounts)
I have not been back to the track/autox since installing the new suspension bits, RE71RS/Volks, and CSG pads. My last 86 Cup race I did have the oil cooler and lowering springs. Actually, lowering springs made 2 track appearances so far.
Track and Autocross
  • 04/23/2022 - SCCA autocross, Phoenix region, Arizona Motorsports Park
  • 06/04 and 06/05/2022 - SCCA autocross, SoCal region, Lake Elsinore Storm park
  • 07/29/2022 - NASA DE4, Utah Motorsports Campus (this was my "free" NASA HPDE entry from the purchase, couldn't use it towards TT)
  • 09/17/2022 - SCCA autocross, Phoenix region, Arizona Motorsports Park
  • 09/25/2022 - SCCA autocross, Arizona Border region (Tucson), Musselman circuit
  • 10/22/2022 - SCCA autocross, Phoenix region, Arizona Motorsports Park
  • 10/29 and 10/30/2022 - NASA TT5, Arizona Motorsports Park
  • 11/12/2022 - NASA TT5, Chuckwalla Valley Raceway
  • 12/03/2022 - NASA TT5, Arizona Motorsports Park
  • 12/10/2022 - Club Racer Track day, Chuckwalla Valley Raceway
  • 12/11/2022 - SCCA autocross, Phoenix region, Arizona Motorsports Park
  • 01/15/2023 - NASA TT4, Arizona Motorsports Park (my normal TT4 BMW broke down on 1st day, so filled in with my GR86 to get points :p )
  • 02/12/2023 - Club Racer Track day, Chuckwalla Valley Raceway
  • 04/15/2023 - 86 Cup, Las Vegas outside roadcourse (first event on GT Radials)
  • 04/16/2023 - SCCA autocross, Las Vegas region
  • 09/02/2023 - SoCal Driver Club track day, Chuckwalla Valley Raceway
  • 09/23/2023 - CVR track day, Chuckwalla Valley Raceway CW hot lap, 2:00.81
  • 09/24/2023 - CVR track day, Chuckwalla Valley Raceway CCW hot lap, 2:00.97
  • 11/05/2023 - PCA track day, Spring Mountain Charleston Peak CW hot lap, 2:38.17
  • 12/02/2023 - SoCal 86 Cup, Chuckwalla CCW hot lap, 2:01.146
  • 12/03/2023 - SoCal 86 Cup, Chuckwalla CW hot lap, 2:00.688
  • 01/27/2024 - SCCA track day, Chuckwalla CCW hot lap, 2:01.53
  • 03/23/2024 - SoCal 86 Cup, Chuckwalla CCW hot lap, 2:00.638
Going forward I'll add updates as they happen
justinco is offline   Reply With Quote
The Following 9 Users Say Thank You to justinco For This Useful Post:
CSG Mike (08-25-2023), ihavefat (08-02-2023), Jianlun (08-02-2023), jongers (08-09-2023), MrSkubi (08-02-2023), new2subaru (08-25-2023), Pat (08-02-2023), Racecomp Engineering (08-02-2023), RedReplicant (08-02-2023)
Old 08-02-2023, 01:13 AM   #2
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
If anyone knows how to make the forum not automatically change my YouTube links into video embeds, lmk (rather have links that are clickable).
The past couple weekends I have been getting my oil pressure setup working and got around to doing some test runs in the canyons a couple days ago.
Data setup
  • GJP IO Box with Honeywell oil pressure sensor and integrated OBD2 port adapter (instead of using OEM OBD2 port)
  • Sensor installed into capped port next to t-body (will test a remote install soon)
  • OBDLink MX bluetooth adapter
  • RaceChrono Pro
Full log of one of the sessions is here : RaceChrono csv log, canyon run 1
Short video snippets below. I'll be doing more further testing as tracks start opening up (too hot in Arizona right now).
The Following 2 Users Say Thank You to justinco For This Useful Post:
Jianlun (08-02-2023), weederr33 (08-02-2023)
Old 08-06-2023, 06:39 PM   #3
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Exclamation
Picked up a couple parts so I can remote mount my oil pressure sensor off the block. Won't be able to get to it for a couple weeks as I'll be out of town racing my BMW this next weekend.
Oil pressure testing will resume after that.
Also, found a Kazama oil pan baffle someone was offloading (nib) and was able to scoop that up. Curious to test that out as well!
nissanfanatic (08-07-2023), RedReplicant (08-07-2023)
Old 08-16-2023, 09:06 PM   #4
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Acquired the Kazama oil pan baffle today. Hoping to get my baseline testing done in early September, then get the baffle installed for follow up testing.
The Following 4 Users Say Thank You to justinco For This Useful Post:
MrSkubi (08-17-2023), nissanfanatic (08-17-2023), RedReplicant (08-17-2023), suaveflooder (08-16-2023)
Old 08-17-2023, 11:35 AM   #5
gnarjunkie
Drives: '23 GR86, '17 BRZ
Nice! That's a big baffle plate. Out of all the ones I've seen, that one seems like it would logically make the most sense.
Not that that necessarily means much lol
gnarjunkie is offline   Reply With Quote
Old 08-24-2023, 12:47 AM   #6
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Chuckwalla track day on 9/2, running both CW and CCW so it will be good opportunity to test oil pressures on the track (pre-baffle). Several tests planned for baseline oil pressure testing on 2 different tire types (SX2 and RE71RS).
Also, remote mounted the oil pressure sensor and test filled my bare oil pan to see how much oil it holds (2qts).
The Following 3 Users Say Thank You to justinco For This Useful Post:
DocWalt (09-18-2023), Pat (08-24-2023), RedReplicant (08-24-2023)
Old 08-24-2023, 06:27 PM   #7
gnarjunkie
So you dropped the pan but didn't put the new baffle in?
Old 08-24-2023, 07:08 PM   #8
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
It is a spare, new pan. Have not dropped the pan yet for the baffle.
Old 08-25-2023, 01:29 PM   #9
gnarjunkie
Ah gotcha. I was thinking that seemed like a lot of effort to see how much oil it holds.
Looking forward to seeing how the new baffle works!
Old 09-09-2023, 04:51 PM   #10
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
First event at Chuckwalla post summer break. Track was super dusty and slick, add GT Radials to that and it was a slow drift fest most of the morning. This was one of the few tame laps I got in before monsoon storm rolled in. My fastest time (this lap below) was 4.5 seconds slower than when my GR86 was nearly bone stock :o
This was also my baseline oil pressure testing day where I gathered some good data on right turn oil pressure loss. Kazama baffle will be installed next weekend, then back to Chuck on 9/23 and 9/24 for baffle testing.
DocWalt (09-18-2023), Jianlun (09-09-2023), RedReplicant (09-10-2023)
Old 09-10-2023, 04:01 PM   #11
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Also, here is the oil pressure testing video from the same Chuckwalla track day. Going back in 2 weeks with the Kazama baffle installed!
The Following 5 Users Say Thank You to justinco For This Useful Post:
cueball89 (09-18-2023), DocWalt (09-18-2023), Petah78 (09-10-2023), RedReplicant (09-18-2023), Spuds (09-13-2023)
Old 09-18-2023, 04:22 PM   #12
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Can't wait to see the Kazama video!
Thank you for documenting everything so well!
The Following User Says Thank You to DocWalt For This Useful Post:
justinco (09-18-2023)
Old 09-18-2023, 06:54 PM   #13
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Kazama baffle installed this past weekend. Testing this Saturday/Sunday!
cueball89 (09-18-2023), DocWalt (09-18-2023), nissanfanatic (09-18-2023)
Old 09-18-2023, 07:18 PM   #14
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Been watching a lot of your video's lately and just wanted to say thanks! They are very helpful and high quality. Keep it up
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
justinco (09-19-2023)
Anyone have any updates for their 2022 GR86? Icekraks AUSTRALIA 0 01-29-2023 08:15 PM
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
2022 GR86 or keep my modified 13' frs jiffyjhn GR86 General Topics (2nd Gen 2022+ Toyota 86) 75 02-19-2022 12:59 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 GR86 MSRP 2k over the BRZ? mangler CANADA 5 12-06-2021 10:51 AM
