08-13-2023, 06:39 AM | #1 |
Drives: 2015 Scion FRS
E85 MPG
Does the OFT v 4.03 E85 tune correct for worse mileage in the dashboard MPG readout? Is it accurate for E85. Thanks all, great forum
08-13-2023, 09:47 AM | #2 |
Drives: Toyota GT86
No, doesn't correct for E85. Wayno tunes do.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
08-19-2023, 11:14 AM | #3 |
Is there a correction needed? Isn’t the system measuring volume of fuel per mile? E85, or normal gas, a gallon is a gallon.
The Following User Says Thank You to Grady For This Useful Post: | Sapphireho (08-19-2023) |
08-29-2023, 01:09 PM | #4 |
Drives: 2014 BRZ
There is an adjustment needed, but the latest oft roms should have it already. It's needed because the mileage display is based on fuel rail pressure which isn't changed by an e85 tune. It's called fuel display multiplier offset in my RR definitions, under misc.-other.
