Tracking / Autocross / HPDE / Drifting What these cars were built for! |
09-01-2023, 04:30 PM | #1 |
Drives: 2016 Scion FRS Release Series 2#439
Oil Pan Baffle Plate. Blue Moon, Moroso, Greddy, Other?
Leaning toward the Blue Moon baffle plate for my Edelbrocked FA20 which sees weekend cruiser and HPDE/Lapping day duties.
All educated opinions/advice welcome. Thx!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
09-02-2023, 11:34 AM | #2 |
Drives: Toyota GT86
I would be curious to see what others have to say. I just invested in an oil pressure gauge to see if a baffle would even be helpful. I’m probably just being blind but I haven’t seen much about oil pressure drops due to cornering on the fa20. The fa24 is a different story of course ha
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
09-02-2023, 12:03 PM | #3 | |
Drives: 2018 BRZ
Granted, there are some fairly consistent recommended parts for street (camber bolts, better tires) and track (oil cooler (with a minority saying they're not needed)) that I would be comfortable putting on my car (and have in fact done so) solely based on the forums' combined wisdom. AFAIK an oil pan baffle for the FA20 is not a strong recommendation and should be installed only if you actually have a problem. |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | autoracer86 (09-02-2023) |
09-03-2023, 12:19 PM | #4 | |
I must soon remove the oil pan to resolve its RTV leak and thought this a good time to slip in a baffle plate. Perhaps, by the sounds of it I should just throw that coin into the track tire kitty. More input welcome. Keep it coming.
The Following User Says Thank You to Muskoka800 For This Useful Post: | Ohio Enthusiast (09-03-2023) |
09-04-2023, 05:23 PM | #5 |
If you're going to put in the baffle, I'd suggest also installing a Killer B pickup (or equivalent). There appear to be two separate issues that require attention, cornering starvation and high rpm pressure drop.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
09-05-2023, 09:10 AM | #6 |
Verus Engineering has put together a preliminary design on the FA24 baffle that utilizes a divider plate with a "flapper" so to speak that will keep oil at the pickup tube during high G load.
They have not considered the FA20 yet but I'd like to poll interest somehow to convince them otherwise.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | RT-BRZ (09-05-2023) |
09-05-2023, 09:29 AM | #7 | |
I thought Killer-B used to make a baffle plate for FA20 however it is no longer visible in there site. I do have their pick-up installed.
09-05-2023, 09:30 AM | #8 | |
FNG
Drives: 2013 Subaru BRZ
09-05-2023, 09:37 AM | #9 |
Blue Moon is for prevening slosh into the upper pan. Verus IIRC is trying to target left to right slosh
Kyle H. - #89 STX
09-05-2023, 11:59 AM | #10 |
Drives: Crapcan
I didn't notice much difference with a baffle. Now that being said, I haven't logged my data, just what I have seen on my gauge. My car also threw a rocker arm and exploded spectacularly 2 sessions in so I don't have a lot of data
09-07-2023, 03:04 PM | #11 | |
Drives: Tacoma
https://koruworks.com/make-model/toy...xoCZZsQAvD_BwE |
09-07-2023, 03:15 PM | #12 | |
Kyle H. - #89 STX
01-25-2024, 08:06 PM | #13 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Going to bump this with thread with my experience after installing a GReddy baffle plate and a Killer B pickup tube.
I was consistently seeing pressure fluctuations on straightaways, the same as @ajc209 reported having with the original Moroso baffle. This winter I will be removing the baffle plate. I don't want any oiling issues, especially with the extra power coming from the Jackson Racing Supercharger I am about to order, so I am doubtful I will replace it with a differently designed baffle. Unless someone has one that has proven to be helpful? |
01-25-2024, 09:06 PM | #14 |
it appears a accusup system might be the best fix based gen 2 testing.
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Similar Threads | ||||
Brand new : Moroso oil pan baffle | Joesurf79 | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2021 10:00 AM |
Compatibility: Moroso Baffle and Killer Bee Oil sump | Nightflo | Engine, Exhaust, Transmission | 3 | 04-27-2019 09:40 PM |
Greddy Oil Pan Baffle Plate | empower-auto | Engine, Exhaust, Transmission | 2 | 03-30-2017 05:08 PM |
Moroso Oil Pan Baffle | acj47 | Engine, Exhaust, Transmission | 6 | 03-05-2015 11:45 AM |
Review/Thoughts on Moroso Alum. Oil Pan Baffle? | Kiske | Engine, Exhaust, Transmission | 1 | 01-06-2015 06:06 PM |
