Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-14-2023, 09:13 PM | #1 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Snout dragging
I admit I'm not very good at gauging distances when approaching a parking-place curb stone. Having said that, this thing is low. When I first got it I put a curb alarm on the front which extended below the front lip not more than 1/2 inch, but it still would bottom just on dips at intersections and only lasted a couple weeks after being bashed too many times.
I'd like to put different suspension on it, but everything I've looked at lowers it even more. So I have a scheme. I'm going to hard-wire an old wireless backup camera somewhere up front and mount the screen inside. If it works as I think, I should be able to see the curbs before I hear them. I'm told the display will be reversed left to right, but fore and aft is all that concerns me. Last edited by Qwimby1; 09-14-2023 at 09:29 PM. |
09-15-2023, 10:13 AM | #2 |
Back in?
The Following 2 Users Say Thank You to Grady For This Useful Post: | humfrz (09-23-2023), The Red One (09-15-2023) |
09-15-2023, 11:29 AM | #3 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Then the exhaust tips get bent to h* & gone.
One of the spikes of a parking stop was sticking 1/4 inch up over the top. Got my fascia stuck on it and ripped a chunk out the first week I had the car. First world cussing and sulking ensued.
"I gotta rock." -- Charley Brown |
The Following 2 Users Say Thank You to bcj For This Useful Post: | NoHaveMSG (09-24-2023), Ultramaroon (09-16-2023) |
09-15-2023, 12:57 PM | #4 |
Drives: 22 BRZ limited
Or you could just stop a bit short. Our cars are not long enough that not pulling over the curbing will put you at risk of being hit.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
09-15-2023, 03:55 PM | #5 | |
Drives: 2018 BRZ
Exactly. Enjoy being one of the shortest car on the lot. Parking a foot too far from the curb will still keep you shorter than the F150 you're parked next to. If anything, parking all the way in might cause you to get hit by a speedy driver thinking the spot is empty (when parked between SUVs/trucks/vans). |
09-15-2023, 04:57 PM | #6 |
1st86 Driver!
As above, I always park centered front/back in a parking spot. I never pull all the way up to the curb.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
09-18-2023, 10:55 AM | #7 |
Drives: 2015 Scion FRS-One
I know the feeling. Having a lowered car is a pain to park and navigate on driveway ramps. I have to put special boards I made at the street curb just to get my car out of my garage and onto the street. Backing in has it's own pitfalls and I've grounded the rear on mine on concrete parking curbs with steel rebar sticking up out of them. I've just gotten used to stopping short on either the front or back. If the car is not where I think it should be I just lean inside, put it in neutral, release the park brake and push it into place. These cars are really light and easy to move : )
The Following User Says Thank You to SubyRS1 For This Useful Post: | humfrz (09-23-2023) |
09-23-2023, 11:00 PM | #8 |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
09-24-2023, 12:48 PM | #9 |
Backing in has worked for me, but it's time consuming and cumbersome. I found half my old wireless backup camera the other day and I'm looking for the other part. I think it will be pretty simple to mount the camera somewhere around the front. I know it's easy to think just don't pull in very far, but I don't have the discipline I guess to do that. I'm always afraid somebody's gonna knock the back of my car off.
The Following User Says Thank You to Qwimby1 For This Useful Post: | humfrz (09-24-2023) |
09-25-2023, 08:02 AM | #10 |
10-09-2023, 07:24 PM | #11 |
Señor Member
Not to detract from your camera scheme but there are lifted suspension setups available. The TRD Rallye springs are one example that lift the car around 1/2”
1974 TA22 Celica
2013 86 GT |
10-10-2023, 10:21 AM | #12 |
[QUOTE=Turdinator;3594378]Not to detract from your camera scheme but there are lifted suspension setups available. The TRD Rallye springs are one example that lift the car around 1/2”[/QGOTE]
Good to know. At 60,000 miles I'm assuming the stock suspension is pretty well shot and would like to put something better under there. Problem is everything I've looked at lowers the car rather than raises it. This thing is so low that it bottoms once in a while just going through the dips at intersections. |
Similar Threads | ||||
Transmission snout/retainer replacement. | Xuningshen | Engine, Exhaust, Transmission | 0 | 04-04-2023 04:52 PM |
ACT clutch dragging/not disengaging | FirestormFlex | Engine, Exhaust, Transmission | 5 | 09-14-2020 02:18 AM |
Dragging right rear brakes | allowe | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-09-2019 02:54 PM |
Clutch dragging | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 08-19-2015 02:32 AM |
installed ebc yellow stuff, brakes dragging | etc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-16-2014 07:36 PM |
