Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-23-2023, 05:09 PM | #1 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Throttle problem, maybe
There's a longer version of this on the forced-induction thread, but part of it, I think, might be of interest here
My OBD read 100% throttle correctly before, but now it's reading max 80.8. I pulled the compressor off and cleaned the throttle body, and the butterfly was wide open with the throttle on the floor. But OBD still shows 80.8% throttle. Either the OBD has gone bad, or something else is still affecting my throttle with the butterfly wide open. I wonder what else could be telling it not to produce WOT. I think it would have to be the TPS, TBS or MAF. At least that's all I can think of. It's a little hard to tell for sure if I'm getting WOT because my ESC is working again and it scoots right along. How ESC stopped working for a time is a story for the other forum. |
09-23-2023, 08:52 PM | #2 |
ProCrastinationConsultant
have you flashed to the stock tune(without the motor running) to verify it's not in the tune tables you're using?
09-23-2023, 10:03 PM | #3 |
I haven't tried that, and confess I'd be a little out of my league if I did. I'm concerned that the last time I used the OFT I had a hard time to get it to respond to the tune I wanted. it eventually did. I downloaded all the tunes off of it and have them on file, but I'm concerned about having to switch around.
09-23-2023, 10:52 PM | #4 |
Wheels for Brains
Not sure what to tell you.
When I see 80%, I immediately think max true throttle position. It's how it's always been on the FA20 Maybe you were looking at a different parameter like commanded throttle, throttle pedal position, or other related throttle position variable |
The Following User Says Thank You to EndlessAzure For This Useful Post: | soundman98 (09-24-2023) |
09-24-2023, 12:44 PM | #5 | |
Similar Threads | ||||
Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
throttle dip? | JDM FRS | Issues | Warranty | Recalls / TSB | 18 | 07-07-2013 03:50 AM |
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
