Old 10-17-2023, 09:22 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
***SOLD*** FS: 2013 BRZ K24 Turbo FlexFuel Haltech
Finally selling my money pit...I mean my car...for real this time. Wife wants a house. I guess I do too. I need a break from project cars.
2013 BRZ Limited Manual
Clean Title
Registered Sept 2024
85-90k miles on the chassis
The car has a K24 KPower turbo swap using a Haltech Elite 1500. It has flex fuel, a return style fuel system with dual DW fuel pumps, ID1050 injectors, custom turbo kit with a Pulsar G25-660 turbo, Morimoto FMIC, Greddy Supreme SP exhaust, Gen 2 transmission, custom ClutchMasters FX750 twin disc clutch kit, making around 415whp at 10-12psi with plenty more to go. Has a Jackson Racing Dual Radiator/Oil cooler, Defi gauges, body kit, custom headlights/tail lights, RR Racing BBK, custom wheels, steering wheel, HU, interior trim, and so much more (list below). Should make near 500whp on this setup before you would need to upgrade injectors. I had planned on dynoing the car again with the new clutch, but decided it is time.
Known issues:
--Number of scratches and dings on the car. It was garaged at home and work, so no rust or anything major, but the car is not a show car.
--The OEM Audio + system is amazing, but I'm dealing with a loose connection somewhere in the system that is making the left side of the car have no or low sound relative to the right. I might fix that before the sale.
--Car is registered in California until September 2024, but it won't pass smog without a hookup, so it is being sold as an off-road/track car only.
--NVH, hope you like race cars. It is possible to daily drive the car, but it wants to go fast on a track. It is livable, but it isn't refined. It has sound deadening, but the swap and exhaust make the car loud. Nothing that screams for the police to look, as it has a quiet catback, as far as catbacks go, but it is just a lot for me.
PARTS LIST
https://www.ft86club.com/forums/showthread.php?t=127650
EXTERIOR
-2017+ Bumper
-VLand headlights
-TRS Morimoto D2H HIDs 35w 5500k
-Tom’s Tail Lights
-OLM Vertical DRLs
-Bayson R STI Replica Kit
-Authentic TRD Spoiler
-Custom from forum member 3rd Brake Light
-Custom emblems from IG:Pete39sp further customized
-Smoked Front Markers
-Custom Vented Fender Garnish
-DD LED Exterior Lights
-Llumar 80% ceramic front, 50% ceramic sides, 20% metallic tint Rear
-Redline Hood Struts
-Natika Backup Camera (12V)
INTERIOR
-FT86Speedfactory Steering Wheel-Leather
-JDM Alcantara Instrument Cover
-JDM Black Buttons
-JDM frameless rear view mirror
-JPM Coachwork Dash
-OEM Knee Pads
-OEM Speaker Pads w/ Black Rings
-OEM Armrest
-MCE Aluminum Pieces
-Perrin Drift Button
-OLM Dry Carbon Fiber Steering Wheel + shifter Covers
-DD LED Interior Lights
-Ortizcustompods Cluster Trim
-Vent Gauge Bezels
-Defi Gauges: Boost, Oil Pressure, Oil Temp
-Weathertech floor mats
-Kenwood DDX919WS
-kenwood DRV-N520 Dash Cam
-OEM Audio Plus Reference 500Q
-Noico Sound Deadening Entire Interior
DRIVETRAIN PERFORMANCE
-K24A2 engine swap (see swap thread)
-Fluidampr Damper
-Fumoto Oil Valve
-Custom G25-660 turbo kit:
--Pulsar G25-660 turbo
--Pulsar 44mm wastegate
--Pulsar 50mm BOV
--BlackMarketFab turbo manifold
--Custom downpipe, front pipe and dump tube
--Mishimoto S-Line Intercooler
--Fireshield turbo blanket
--DEI header wrap
--Custom IC pipes
-Greddy Supreme SP Catback
-KPower Industries swap kit
-Haltech Elite 1500
-Haltech Flex Fuel sensor
-Haltech EBC
-ID1050x Injectors
-Radium Fuel Pulse Damper
-Radium Boost Reference FPR
-Fuel Pressure Meter
-Fuel pressure sensor
-DW Dual Fuel Module for return fuel system
-DW Fuel filter
-Hobs fuel pressure switch
-Jackson Racing Dual Radiator Oil Cooler
-Greddy oil cooler sandwich plate
-Gen 2 Transmission swap
-Clutch Masters FX750 twin disc
-Verus Clutch fork and pivot
-Whiteline Transmission Bushing
-MTEC Shift Springs
-Shortened Driveshaft
-Clutch Spring Removal Mod
-Shorter Clutch Pedal Mod
-Shorter Brake Pedal Mod
-Lightweight Shorai 4.5lb Battery
SUSPENSION/BRAKES/WHEELS N TIRES
-Eibach Pro Kit Springs
-Eibach Pro Sway Bars Front and Rear
-RR Racing STAGE 2 Front BBK
-RR Racing Sport Performance Rear BBK
-Grimspeed Master Cylinder Brace
-XXR 530 Black Chromium 18x7.50 +38
-Michelin Pilot Sport 4S 235/40/18
-XXR 530 Black Chromium 18x8.75 +33
-Michelin Pilot Sport 4S 265/35/18
-Muteki Open Ended Lug Nuts
-ARP Extended Lug Bolts
-FactionFab 10mm Wheel Spacer (Front only)
-Whiteline Positive Traction Kit
-Whiteline Support Outrigger Insert
-Blitz Strut Tower
-True Focus Fab Crash Bar
SWAP PARTS
https://www.ft86club.com/forums/showthread.php?t=145419
OEM Components
--K24A2 RBB JDM engine from a 2003-2008 Acura TSX (Purchased)
--K20 water pump and housing (Purchased)
--K24 USDM accessories (Purchased)
--Water plug 90001-PM3-003 + washer 90401-PR4-000 for turbo water return (Purchased)
--RSX Type S oil pump kit (Purchased)
--50 degree VTC gear (Purchased)
--EP3 K-Tuned Pulley (Purchased)
--Refresh components like spark plugs, oil and filter, thermostat, gaskets/seals, etc (Purchased)
--***ARP K series manual flywheel bolts (Purchased)***19mm head will not fit***
--OEM K series manual flywheel bolts (Purchased)
--Stock FA20D throttle body (Retained)
--Stock 86 ECU (Retained)
--Stock clutch, clutch fork, pivot, TOB (Retained)
KPower Swap Kit
--Haltech Elite 1500 with base maps configured for wiring harness (Purchased)
--Kpower Engine wiring harness and sensors (Purchased)
--KPower Engine mounts (Purchased)
--KPower Oil pan (Purchased)
--KPower Intake Manifold (Purchased)
--KPower TB adapter (Purchased)
--KPower Transmission mounts (Purchased)
--Kpower Transmission adaptor w/ block off plate (Purchased)
--Kpower Aluminum flywheel (Purchased)
--Kpower Shifter relocation (Purchased)
--Kpower Shifter arm (Purchased)
--Kpower Aluminum driveshaft (Purchased)
--Kpower Fuel rail (Purchased)
--Kpower Rear/Upper coolant housing/neck (Purchased)
--Kpower Heater pipes (Purchased)
--Kpower AC kit (Purchased)
--Hybrid Racing thermostat plug (Purchased)
--Kpower water pipe adapters (Purchased)
--Kpower silicone water pipes (unavailable)
--Gates 23383 upper radiator hose (Purchased)
--Dayco 71718 lower radiator hose (Purchased)
--1.5” to 1.25” adapter x2 (Purchased)
--Kpower hydraulic released bearing (unavailable)
Turbo Kit
--Garrett G25-660 replica by Pulsar (purchased)
--Turbo blanket (purchased)
--Tial 44mm wastegate replica by Pulsar (purchased)
--Turbosmart 50mm BOV replica by Pulsar (purchased)
--Black Market Fab RWD Turbo Manifold (purchased)
--BlackMarketFab Downpipe/recirculation tube 50% (purchased)
--Custom downpipe to stock frontpipe (Purchased)
--Oil return T25 flange to -10AN male end (purchased)
--2NRS Oil return bung for timing chain tensioner cover (purchased)
--Greddy oil cooler sandwich plate w/ PT adapter and plug for sensors and oil feed (purchased)
--TracTuff -6AN water pump/block adapter (Purchased)
--AN lines (Purchased)
--Silicone vacuum hoses (Purchased)
--Morimoto S-Line Intercooler Black (Purchased)
—IC pipes and couplers (Purchased)
--ID1050x injectors and adapters (Purchased)
--Haltech Flex Fuel sensor (Purchased)
--Haltech EBC (Purchased)
--Skunk2 4bar Map Sensor (Purchased)
Asking $25k.
***SOLD*** Sold to me. Gonna keep the car for a while.
Irace86.2.0 is offline
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
rixter145 (11-11-2023)
Old 10-17-2023, 09:23 PM   #2
Irace86.2.0
Crappy video of a dirty car for the time being just to get something up.
Old 10-17-2023, 09:38 PM   #3
Irace86.2.0
Some pictures. Many more can be found in my build thread.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
DarkPira7e (10-19-2023), frs23 (10-19-2023), RedReplicant (10-17-2023), Teseo (10-19-2023)
Old 10-19-2023, 10:54 AM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
2. You must post AT LEAST ONE picture of the item(s) for sale with a sign included in the photo. On the sign, should be your username, date and the words FT86Club.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Thanks,
ichi
ichitaka05 is offline
Old 10-19-2023, 11:58 AM   #5
Teseo
Drives: frs
Thanks,
ichi
Really, lol?
His license plate doesn't count? 😂
Teseo is offline
The Following User Says Thank You to Teseo For This Useful Post:
Irace86.2.0 (10-19-2023)
Old 10-19-2023, 11:59 AM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Originally Posted by Teseo View Post
Really, lol?
That part count... just missing the date & FT86Club
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Jdmjunkie (10-19-2023), Teseo (10-19-2023)
Old 10-19-2023, 08:42 PM   #7
Irace86.2.0
So sorry. Of course we all need to follow the rules. Here’s a few pictures of my car with my sign. I added a little artistic flair—some Portrait Mode to give it that bokeh pop.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
alex87f (11-04-2023), ichitaka05 (10-20-2023), pward08 (11-04-2023)
Old 11-02-2023, 10:32 AM   #8
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I can't tell if this is your car or not, the car is blurry in the background. Could be anything...
J/K lol
GLWS man if I didn't have a JZ 86 i'd be all over this.
Any interest in trading for a k swap, turbo s2000? My buddy saw this and told me to ask lol.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline
Old 11-04-2023, 02:52 AM   #9
Irace86.2.0
J/K lol
There is a short list of cars I would consider a trade for, and these are the following cars (stock or tasteful modz): GR86 (manual), Cayman (981/982 PDK/manual), 911 (997/991), TTS/TTRS (MK3), Lotus Ever, GR Supra (manual), Miata RF (manual), E89 Z4, M2 and Model 3.
I wouldn't get a GR86 without a CARB Harrop kit released, probably. I probably should move on from this platform, or I'll spiral down the modification wormhole.
Teseo (11-10-2023)
Old 11-09-2023, 11:33 PM   #10
Irace86.2.0
Updated with the fix on the clutch. Working perfectly now.
Old 11-10-2023, 09:42 AM   #11
Teseo
Drives: frs
Get Porsche, pain in the ass to modify
Teseo is offline
Irace86.2.0 (11-11-2023)
2013 frs Turbo/built motor/flexfuel Kurd Cars for Sale/Trade 6 03-03-2021 05:29 PM
NJ. 2016 SCION FRS TURBO FLEXFUEL, M/T NFS86 Cars for Sale/Trade 10 10-31-2019 09:57 AM
2013 Argento FRS (Dallas) 25k miles,Borla,FlexFuel,Ecutek $17500 doberman8u Cars for Sale/Trade 6 06-11-2016 02:58 PM
*** CMS TUNING l Stage1 l Stage2 l E85 l SC l Turbo l FlexFuel l Custom Circuit Motorsports Engine, Exhaust, Bolt-Ons 581 04-12-2016 10:03 AM
Prime Motoring/Jr Tuned P&L Motorsports Stage 1 Turbo Kit/FlexFuel FRS 424Whp-324tq PrimeMotoring Forced Induction 44 04-11-2014 07:39 PM
