Old 02-16-2024, 03:34 AM   #1
SAWYER
SAWYER's Avatar
Drives: 2013 Scion FR-S (Base)
Angry Driver side Window Switch Panel Wont Turn Off
When installing Driver and Passenger Window Switch Panels with swapped White LED's from Automotive Custom Lighting , I came across an issue. The Driver Side Panel lights do not turn off at all. The lights remain on when the car is locked, when DRL Lights are off, and when the ignition is not turned on.
Yet the Passenger Panel works completely as expected, the lights turn off when the car is locked and when the car has the ignition turned off.
I had checked all fuses, and they are all intact and functional.
The only way I can get the Driver Panel lights to turn off is to remove the fuse that powers it.
Please see attached photos. I had recorded a video explaining this issue as well:
( https://youtube.com/shorts/n8HHJJ59v...G1oLDOURz8kAAe )
SAWYER is offline   Reply With Quote
Old 02-16-2024, 08:00 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
If you put back the stock panel does it show the same behavior? If so, I suspect a pinched wire in the wiring harness shorting out something. If not, the problem is with the aftermarket panel/LEDs/swapping-work.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
x808drifter (02-16-2024)
Old 02-16-2024, 05:25 PM   #3
SAWYER
SAWYER's Avatar
I had confirmed that the stock panel does NOT follow this behavior. The stock one works as expected and in unison with the Stock Passenger side; they remain off unless the Ignition is turned to the ‘On’ position.
Must be a sloppy soldering job done by the guys who swapped the LED’s. I will be shipping the broken panel back out to them to have their guys take a look.
The Following 2 Users Say Thank You to SAWYER For This Useful Post:
bcj (02-16-2024), x808drifter (02-16-2024)
Driver Side Window Switch issues Drake_93 Issues | Warranty | Recalls / TSB 1 04-16-2023 08:37 PM
Push pin or screw? Driver side under panel (interior) Packofcrows Issues | Warranty | Recalls / TSB 3 04-04-2018 05:57 PM
Driver side window/switch issue MRCA1ST Issues | Warranty | Recalls / TSB 4 03-06-2018 01:11 PM
Driver side window/lock switch issue xoBethxo Electronics | Audio | NAV | Infotainment 3 04-01-2016 12:09 AM
wtb:Window visors, shark fin, fog lights, switch backs, clear side markers Vincenttam Want-To-Buy Requests 13 06-28-2014 04:02 PM
