BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
03-15-2024, 06:03 PM | #1 |
Drives: 2023 Gray BRZ
Oil Pressure Drop
Latest from 900BRZ:
Yeah!! So the best solution: large capacity oil plan + integrated baffle. Excellent video to go along with it, explaining the experiment and logic. Can't wait to see the final product! Last edited by OldBiker; 03-15-2024 at 10:58 PM. |
The Following 6 Users Say Thank You to OldBiker For This Useful Post: | BatStig (03-16-2024), CaptainFenderbaum (03-16-2024), Gearhead23 (03-16-2024), vindiesel (03-16-2024), whataboutbob (03-15-2024), ZDan (03-24-2024) |
03-24-2024, 08:14 AM | #2 |
Drives: '23 BRZ
Yeah, that looks like the ultimate answer. Meanwhile before pan is available, Accusump looks like the best solution at the moment.
Tryna decide whether to go ahead and get Accusump and then the deeper aftermarket oil pan solution when it is available, or get an ND2... |
03-24-2024, 10:25 PM | #3 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
03-25-2024, 04:42 PM | #4 |
Drives: '23 BRZ
Yeah no way it would stay on stock suspension, would be getting coilovers, roll bar, and a lower and more supportive drivers seat right away. We are spoiled with BRZ seats!
03-25-2024, 09:00 PM | #5 | |
Drives: 2013 BRZ Satin White Pearl
03-25-2024, 09:52 PM | #6 | |
AutoX-10/10ths every run
I'm pretty sure the 1st gen had issues. Especially if; 1) You let the oil get low and then drove it hard, 2) Added FI, and/or: 2.a) Let the oil get low, 2.b) Drove it hard, 2.c) Didn't address the oil cooling issues, 2.d) Had a shitty motor build (OEM or aftermarket), or 2.e) All of the above
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
03-26-2024, 06:53 AM | #7 | |
Drives: Toyota GT86
On the second gen oil pressure will drop on track based on load from right hand turns regardless of the temperature. Street driving seems to be fine so if you don't track your car its not much of an issue
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
03-26-2024, 09:30 AM | #8 | |
Drives: '23 BRZ
I tracked my 1st gen ~12 track days/year for five years, I wasn't monitoring oil pressure though. Anyway I test-drove an ND2 last year and it was a hoot, reminded me a bit of my old 240Z being similar weight (slightly heavier) and with driver sitting right at the rear wheels. I got the '23 BRZ because more utility as it was going to be my only car. Since then I've picked up an '05 Mazda3 hatch as a daily so the ND2 is more of an option now. Also I've been having to run a ton of ballast for time trials, and for this year they've added 80 lb. more Victory ballast... So anyway my competition weight with the '23 BRZ would be 3187 lb. this year. Kinda nullifies one of the best things about the car... Even at 3107 lb. last year I could *feel* the mass. Could run ND2 at 2475 lb. which sounds like fun... |
The Following User Says Thank You to ZDan For This Useful Post: | Dirty Harry (03-27-2024) |
03-26-2024, 11:14 AM | #9 | ||
Drives: '23 BRZ
And anyway you can easily go to 40-weight if want higher pressure at temp with no oil cooler. I did a pretty exhaustive search when I got my car in late 2017 and found that engine failures were not correlated at all with whether or not an oil cooler was present. In fact it seemed to me that *most* track failures were *with* an oil cooler. There were RTV issues and general oiling issues particularly for #3 not related at all to oil temperatures. Again, 275F indicated/255F sump was never the problem... |
The Following User Says Thank You to ZDan For This Useful Post: | blsfrs (03-26-2024) |
03-26-2024, 11:46 AM | #10 | |
Drives: Toyota GT86
03-26-2024, 12:48 PM | #11 |
Drives: '23 BRZ
03-26-2024, 05:30 PM | #12 | |
Drives: '23 BRZ Limited
And FM has stronger case bolts for the transmission because the case itself twisting was found to be the reason cars tracked hard were having transmission failures.......I don't remember if they made the cases stronger for ND2s.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
03-27-2024, 10:39 AM | #13 | |
Drives: '23 BRZ
03-27-2024, 10:56 AM | #14 |
Drives: 2022 BRZ sport-tech
Interesting, i have heard that the ND2 has a glass trans which never got resolved this is up to 2023. The only solution was to swap in a NC 6sp. This is the first i have heard about the requirement for a diff/trans/engine cooler.......
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
Tags |
900brz, fa24, oil pressure |
Similar Threads | ||||
Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results | Ansix Auto | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 49 | 09-14-2023 08:35 PM |
Should an oil cooler cause oil pressure to drop? | blsfrs | Engine, Exhaust, Transmission | 6 | 07-30-2023 09:28 PM |
Fuel Pressure Drop on my LS BRZ | Shahano | Engine Swaps | 6 | 04-28-2021 04:57 PM |
Intermittent fuel pressure/signal drop (Fuel regulator prob?) | Decimus | Issues | Warranty | Recalls / TSB | 6 | 03-27-2019 07:38 PM |
Temperature drop, tire pressure check! | radroach | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 11-07-2016 08:43 PM |
