Old 03-24-2024, 07:32 AM   #1
boi
Drives: 2013 Brz
Can anyone help with foglight install 2013 brz with 2017 face-lift
Hey everyone in need of some help installing these foglights on my 2013 premium brz with a 2017 face-lift. I'm trying to use the factory harness to get it working I've already installed the fog light stalk and the light comes on in the dash but I can't get the fog lights working. I made a harness using the daytime running lights any help would be greatly appreciated
boi is offline   Reply With Quote
Old 03-25-2024, 01:32 PM   #2
SuperSub7
Drives: Awesome
Hi there! since the light on the dash comes on, it means that your fog light stalk is installed correctly and the circuit to the indicator light is complete and it also means part of your wiring is working properly. Check your harness connections and make sure that the wires aren't loose or frayed as in can cause short circuits. Also, it might be a compatibility problem, if the system doesn’t recognize the fog lights, it may not power them.
SuperSub7 is offline   Reply With Quote
Gen 1 face-lift 2017-2020 for SSC? Balefire Tracking / Autocross / HPDE / Drifting 7 12-28-2021 06:56 PM
OEM Foglight install help rotortoaster DIY (Do-It-Yourself) Guides 0 05-01-2020 05:55 PM
air lift install pictures? all4spl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-17-2016 12:49 PM
DIY: Air Lift Suspension Install RallySport Direct DIY (Do-It-Yourself) Guides 63 04-16-2016 11:42 PM
Turbo, Convertible, Face-Lift in 2016.. TOYSTRY BRZ First-Gen (2012+) -- General Topics 14 04-02-2014 08:23 PM
