Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-18-2024, 09:35 PM | #1 |
Drives: Subaru BRZ 2016
87mm High Comp Pistons
Toda Power Liner Kit Toyota GT-86 2012+
Toda Increased Capacity 2300 KIT Toyota GT-86 2012+ -or- HKS 2.2L Complete Engine FA20 Step 3 Subaru | Scion | Toyota 2013-2020 If I where to use these kits to increase engine capacity. Why is it seemingly impossible to find high quality 87mm High compression ratio pistons? I want 87mm Pistons, 12.5 cr or 12.7 cr. Or is it possible to modify the HKS Pistions before ordering? I want higher compression ratio and bigger bore. Also, I need the valves to match. -I dont care about FI(Forced Induction), as I am a NA (Naturally Aspirated) fan, and will remain that way. |
04-19-2024, 06:06 AM | #2 |
Drives: brz 2017 hksv2
with the cost of those is probably cheaper a long block fa24 and goes faster..
04-19-2024, 07:58 AM | #3 |
Drives: Toyota GT86
Umm the prices online are 30-40k for this are you really going to spend that much on a gt86 motor
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-20-2024, 04:39 AM | #5 |
Drives: 2013 86
It is impossible, so I decided to improvise. Custom made 90mm 11.5:1 pistons and custom sleeves. Modified OEM head gaskets. Just under 2.2L on the stock crank.
04-20-2024, 04:44 AM | #6 |
Drives: 2013 86
Sleeves were made by LAsleeve. They'll likely make you another set if you ask them. Some of the forged piston manufacturers will do custom stuff. Gaskets are trickier... I got greedy and had to machine a bit out of stock ones to get 90mm. If you keep it sensible the stock gaskets are good for 89.5mm
Similar Threads | ||||
High compression forged pistons? | jRuN | Forced Induction | 1 | 01-14-2020 10:06 PM |
High Compression pistons | EN2_Squirrel | Engine, Exhaust, Transmission | 23 | 05-01-2014 02:29 PM |
13.5:1 Pistons | woode | Forced Induction | 13 | 04-27-2014 11:06 PM |
Best pistons to use and Comp ratio? | Fabron757 | Forced Induction | 36 | 02-05-2014 03:21 PM |
12.5/1 Comp Forged Rods and Pistons | Darryljr11 | Engine, Exhaust, Transmission | 1 | 10-26-2013 07:11 PM |
