Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-23-2024, 07:10 PM | #1 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Run time between pits for enduro?
Thinking of doing a last minute race and trying to figure out if I want to race the 86 or Miata. Basically wondering if I can go 1.5 hours between stops.
Car is a stock engine with a tune, intake, headers and catback.
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. |
04-24-2024, 12:40 PM | #2 |
Drives: 2013 frs base
My car has a similar set up. In NASA HPDE 2, Three 20-25minute sessions takes me to 1/4 tank. I always add fuel after my 3rd session to avoid the risk starvation. You might get an hour.
04-25-2024, 02:41 PM | #3 |
That was kind of my thinking. I'm considering adding a surge tank, but need to look and see what WRL will allow. I'm not going to race for a championship, but I'd like to do 2 WRL races a year.
04-25-2024, 06:28 PM | #4 |
Drives: None
People mod the NB tank slightly and it holds almost 14gal, decent power NA build and that'll be right around two hour stint times. Stock power and stock NB tank will probably be right there around two hours too.
86 too fat and too much power to see anything like that without going to a large-ish fuel cell.
04-26-2024, 11:36 AM | #5 | |
Would encourage you to work with a tuner that can specifically help you achieve that long stint time. |
04-28-2024, 07:15 PM | #6 | |
WRL will let me run a larger tank. Is there a fuel cell option to get ~16.5 gallons (and half a gallon for a surge tank).
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. Last edited by GrandSport; 04-28-2024 at 07:30 PM. |
04-29-2024, 05:06 PM | #7 | |
Are you planning on deleting the stock tank, or adding to the stock tank? If adding, then a fuel cell with hydramat feeding the engine, with the stock tank feeing the cell, can effectively replace the surge tank for you AND get you the extra fuel you need. I think this should be obvious to most folks reading this, but just in case, you'll want to have full fire gear at all times in this car moving forward, as well as a full fire supression system. Multiple nozzles with at least 2 pointed toward the driver. |
04-29-2024, 06:49 PM | #8 |
Drives: None
While the suggestion above is a decent idea, it's worth looking into WRL and other series you're interested in running.
NASA calls anything larger than .4gal a fuel cell instead of a surge tank, so you get to deal with fuel cell rules. WRL calls anything larger than .5gal an aux tank, so you get to deal with fuel cell rules and have to size to fit into the max fuel capacity for the class. Stock BRZ tank is advertised as 13.2gal so you're kinda in an awkward spot sizing wise (3gal aux tank).
04-30-2024, 01:14 PM | #9 |
If I run GP2, it's 0.051*rwhp +7.5
Assuming 185-190rwhp, I get 16.9-17.2 gallons. I could, in theory, add 3.5-4 gallon surge tank and go from there. After there, it's just how much we want to spend. We could spend a to on of time on the dyno to lean it out and ceramic coat pistons and etc. I wish there was a series just like WRL, but one that just had mandatory pit stops X often that are minimum x minutes long so the race wasn't entirely won and lost in pits. If you can make one less stop, you win. Make it tight, so you can gain/lose some time in the pits, but not so that you need a god damn engineer to travel with the team. This would be very ideal for amateurs that want to do a long enduro race with their friends, and not spend crazy amounts of money. I think it would also keep big money racers uninterested. edit: and yes, I run full fire protection every time I get in the car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. Last edited by GrandSport; 04-30-2024 at 01:29 PM. |
Similar Threads | ||||
Show off your pits thread | FR-S2GT86 | Off-Topic Lounge [WARNING: NO POLITICS] | 33 | 05-03-2021 02:00 PM |
Enduro Kart Racing at Andersen Racepark FL | Twinz | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-17-2017 05:05 PM |
Seat Pits/Depressions | TennisHsu | Issues | Warranty | Recalls / TSB | 30 | 03-15-2016 03:11 PM |
R&T Tires-up Scion FR-S and Pits it Against the Impreza WRX and Mazdaspeed3 | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-18-2012 11:52 PM |
Tint, pits, and bra's | michaelahess | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 07-13-2012 07:24 PM |
