Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-27-2024, 05:13 PM | #1 |
Drives: 2013 Scion Frs
P0172 and P1170 Codes
Hi, I recently had a check engine light pop up, and got the code read. The codes were P0172 (System too rich bank 1) and P1170 (Fuel performance/Port injector) But I decided to be responsible and take it into a shop. They told me that I needed to replace my AFR sensor, as well as my MAF sensor, also said that an oiled filter may cause the issue. But they quoted me $1400 for the repair so decided to do it myself for around $300 and replaced the air filter because it needed to be changed either way. It turns out that it was not the problem, and figured it may not have to do with the sensors being broken, but the sensors sensing something is wrong. Especially since I sometimes smell gas when I am driving. I was wondering if anyone had any suggestions or history with this issue before I try some more of my options.
04-29-2024, 09:16 AM | #2 |
Drives: brz 2017 hksv2
the lambda could be the culprit, as well as bad exhaust leak or faulty injectors
04-30-2024, 01:01 PM | #3 |
05-01-2024, 08:32 AM | #4 |
yeah
what you can do for now is check the 3 bolts of DI ecu inside bonnet near the big fuses box are fully tightened to.ground |
05-01-2024, 08:40 AM | #5 |
Sarcastic SOB
Make sure that MAF sensor is removed and doused with cleaner. Also, you might need a fresh air filter if your oily one inadvertently fouled the MAF sensor and possibly restricted flow.
Regarding injectors, no experience there.
Similar Threads | ||||
P0171 and P1170 codes when at low RPMs or idle | stockysnail | Issues | Warranty | Recalls / TSB | 35 | 12-22-2022 08:27 PM |
Check engine codes P0171, P1170, C1201, C1231, and c1241 HELP | Crystalwhitebrzsti | Issues | Warranty | Recalls / TSB | 10 | 05-30-2019 06:45 AM |
Odd idle and P0171 and P1170 codes | dave- | Engine, Exhaust, Transmission | 0 | 09-26-2018 11:05 PM |
Throwing P0171 and P1170 codes | B-R-Z | Software Tuning | 39 | 01-27-2018 09:56 PM |
Oft Tune E85 Showing Codes P1170 P117B | gonzo | Software Tuning | 30 | 09-05-2015 02:50 PM |
