Old 04-30-2024, 08:39 PM   #1
ThatYeti
Sidemarker Fix
Realize this has been covered a bunch here but looking thru the old posts I'm not seeing an answer other than replace the clips or just zip tie it. Also an option to buy some kind of after market plate that has to be riveted on or something.
Pic of my passenger side as I tried to add new clear ones but noticed I am missing the plastic plug that holds on the fender liner and the old one was just zip tied on which I'm hoping to avoid doing again.
So how do I fix this and what parts if any am I missing (besides the plastic plug with the Phillips on it)
ThatYeti is offline   Reply With Quote
Old 05-01-2024, 07:02 AM   #2
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
The fix recommended in this video works surprisingly well. Also, the OEM silver clips are far better fitting than any aftermarket ones I've handled, so I would recommend picking those up.
gkubed is offline   Reply With Quote
The Following 3 Users Say Thank You to gkubed For This Useful Post:
Teseo (05-02-2024), ThatYeti (05-01-2024), tobin (05-01-2024)
Old 05-01-2024, 07:21 AM   #3
ThatYeti
Appreciate that but on mine it feels like there's something on the car/fender side missing that the sidemarker is meant to clip into as none of the clips seem to seat into anything despite all being present. Any idea what's missing?
Old 05-01-2024, 09:23 PM   #4
gkubed
gkubed's Avatar
It looks like you're missing SU003-01505. You can see that part at 1:50 in the video I linked.
I think you're going to want two rivets like SU003-02940 and one pop clip like SU003-02974 for the installation.
The Following User Says Thank You to gkubed For This Useful Post:
RToyo86 (05-03-2024)
Old 05-01-2024, 11:28 PM   #5
ThatYeti
Thanks but if I never took that part out when I put the aftermarket ones in how would I be missing it? Granted I bought the car used but it has factory side markers on it when I got it. Only swapped to smoked ones afterwards and they were already drilled for zip ties so that's how the shop put them on after pulling the bumper for an oil cooler install.
Old 05-03-2024, 01:33 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Probably the car was an in accident previously, replaced bumper, and the shop never put them on
EndlessAzure is offline   Reply With Quote
Old 05-03-2024, 07:35 AM   #7
ThatYeti
Ok but if that's the case and it's a part that's riveted on wouldn't there be holes from the original part? For what it's worth the car has a clean history and I was told the bumpers were resprayed at one point before I bought it just cause it was a city car and got lots of little scrapes.
Old 05-03-2024, 08:51 AM   #8
EndlessAzure
Wheels for Brains
The holes are molded into the bumper itself. You don't "make" any new holes. You can even see one of the holes you're meant to send a rivet through to attach the side of the bracket in your photo. The other one comes down for the top of the bracket, near where the pop clip is on the photo.
Regardless of what happened, your car doesn't have the bracket.
-- That bracket is something that is often neglected when replacing the bumper, especially if a new replacement was needed and the shop isn't familiar with the car. The brackets don't come pre-installed on a replacement bumper: the brackets and rivets need to be ordered and installed separately. It's not typical for shops to remove them if they don't have to either.
@gkubed already listed all the parts you need (1x passenger bracket, 2x rivets). You should probably check your driver side as well, and order the driver bracket and additional rivets as well if needed.
See this old DIY guide. It shows how the sidemarkers are retained from the factory, some images of the bracket, and how you're supposed to interact with them. https://www.ft86club.com/forums/showthread.php?t=15560 . Zip ties are not the factory retention method. The sidemarker metal tab snaps into the bracket
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
bcj (05-03-2024), ThatYeti (05-03-2024)
LF: Sidemarker Lights yam86 Canada Classifieds 0 07-21-2017 11:02 AM
Helix sidemarker Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 21 01-08-2017 02:02 PM
Boomerang sidemarker scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 10 10-12-2016 08:18 AM
Sidemarker and Sidemarker Light arm broken off while driving. CreinCrein Issues | Warranty | Recalls / TSB 4 05-20-2014 08:49 AM
Water in Sidemarker? jonzhuxD Cosmetic Modification (Interior/Exterior/Lighting) 15 12-31-2013 04:59 AM
