Old 05-01-2024, 11:43 PM   #1
B00STED86
Drives:
Oil cooler install question
So I installed a mishimoto oil cooler. I attached a photo of how I had to install the left fitting to the sandwich plate. I had to have it facing upwards as my turbo is in the way. All the photos ma I’ve seen have it point down. I don’t think this should matter, just want to get someone who is experienced opinion.
B00STED86 is offline   Reply With Quote
Old 05-01-2024, 11:45 PM   #2
B00STED86
Drives:
Old 05-01-2024, 11:45 PM   #3
B00STED86
Drives:
Old 05-01-2024, 11:46 PM   #4
Ashikabi
Ashikabi's Avatar
Direction the hose points won't matter. System is pressurized
Sent from my KB2007 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
B00STED86 (05-05-2024)
Old 05-02-2024, 12:52 AM   #5
Grady
Grady's Avatar
The direction does not matter. Make sure you torque those banjo fittings correct and you may want to drill them and safety them. Banjo fittings do not perform well with a lot of movement.
The Following User Says Thank You to Grady For This Useful Post:
Old 05-03-2024, 01:37 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Seems fine. Just make sure the tension in the hoses tends to pull the fittings toward the tightening direction
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Old 05-05-2024, 03:46 PM   #7
B00STED86
Drives:
Thanks for the piece of mind, fellas
DIY: Greddy Oil Cooler Install JBezugs DIY (Do-It-Yourself) Guides 30 11-16-2022 10:10 AM
oil cooler install near Seattle? BRZrkr Northwest 0 06-08-2022 08:07 PM
Forrester oil cooler with oil to air cooler question ? sroby Engine, Exhaust, Transmission 20 08-01-2019 09:49 AM
Oil Cooler install in the GTA.. Skurj CANADA 53 06-24-2015 02:51 AM
Help! Oil Cooler Install brillo Tracking / Autocross / HPDE / Drifting 13 07-17-2013 04:55 PM
