Old 09-01-2012, 09:06 PM   #1
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Airbag light trick for racing seats.
Warnings:
1)Always disconnect the battery when dealing with Airbags.
2) I am not responsible if you damage your car or yourself during this install
I am assuming if your doing this DIY you have already figured out how to remove the seats and disconnected the the battery and the wires connected to the seat.
First thing you need is a Resister with a resistance of 3.3 Ohms.
[ame="http://www.amazon.com/3-3-Ohm-Flameproof-Resistor-Pcs/dp/B0002ZP0US/ref=sr_1_1?ie=UTF8&qid=1346546875&sr=8-1&keywords=3.3ohm+resistor"]Amazon.com: 3.3 Ohm 1W Flameproof Resistor 10 Pcs.: Electronics[/ame]
Locate the yellow harness .
You will notice that there are only 2 wires connected to the harness but are 4 holes (sorry the picture doesn't really show it, i'll try to get a better one before Install the seat tomorrow morning), you want to plug the resistor into the bottom two holes.
No it does not matter which side of the resistor you plug into which hole.
See no light
Please let me know if I am unclear on anything as I may have had a few beers before writing this :happy0180:, though this is pretty self explanatory and hard to screw up.
Also I am just going to use electrical tape to secure it for now, later I will find the other end of the connector and solder the resistor to that, and insulate it with shrink wrap.
Ricepuddin is offline   Reply With Quote
The Following 15 Users Say Thank You to Ricepuddin For This Useful Post:
37 (08-21-2013), Asphalt (02-17-2013), civicdrivr (09-27-2012), Cop (09-10-2015), DustinS (08-05-2015), Guff (09-25-2012), Hanakuso (09-02-2012), juliog (04-04-2014), LeeMaster (03-16-2013), No Limit Motorsport (08-09-2013), sato (01-17-2021), Scooby South (07-07-2013), tigermack (10-12-2014), Tristor (05-28-2018), UncleFester (09-02-2012)
Old 09-02-2012, 01:44 AM   #2
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
Minor point - the resistor has a resistance of 3.3 Ohms - not impedance.
-J
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
The Following User Says Thank You to Jimbo For This Useful Post:
Guff (09-25-2012)
Old 09-02-2012, 08:34 AM   #3
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
-J
You sir are correct, I must have been a little drunker than I thought
Old 09-02-2012, 12:30 PM   #4
Hanakuso
I'm thinking worse comes to worse. Does anyone know if the airbags will deploy if the wires accidentally detach or resistor fails?
This looks like a great and cheap alternative to the TRD option that will come out soon.
Hanakuso is offline   Reply With Quote
Old 09-02-2012, 12:44 PM   #5
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Do you have any information on the TRD option? I didn't just leave the Resistor out like that, I taped it up pretty tight. I am also going to try to find another seat connector to solder one of my extra resistor so it's a little more secure than tape.
I am not sure about it still deploying with the airbag light on. I do know that this trick has been used for years and I have never seen a resistor open.
Old 09-02-2012, 12:48 PM   #6
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
trd option?
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
The Following User Says Thank You to FT-86GOD For This Useful Post:
AZFA20 (10-08-2014)
Old 09-02-2012, 12:58 PM   #7
Hanakuso
The TRD item im talking about is the "canceller" that comes with the seat rails.
http://www.trdparts.jp/english/86_pe...atestnews.html
Old 09-02-2012, 01:01 PM   #8
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
I would bet that it's just a pretty version of what I did (and probably over priced).
Sent from my Galaxy Nexus using Tapatalk 2
Old 09-02-2012, 01:05 PM   #9
Hanakuso
I'm willing to bet its basically the same but it will be a cleaner install since they will probably make a housing for it. That's how my steering wheel canceller was like
I could see it being reasonably cheap if they sell it without the seat rails
Old 09-02-2012, 03:18 PM   #10
doggy
doggy's Avatar
Drives: Scion FRS Firestorm MT
Airbags will deploy with resistor installed (all other airbags in the car). And if you get short on the wires (if your resistor some how goes 'short') airbags might deploy. So secure your resistor pretty good...
doggy is offline   Reply With Quote
The Following 4 Users Say Thank You to doggy For This Useful Post:
37 (08-21-2013), kiichiro (06-02-2014), Ricepuddin (09-02-2012), Tristor (05-28-2018)
Old 09-02-2012, 09:33 PM   #11
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
If it gets released here in the states it maybe relatively inexpensive (anything over $25 would be over kill to me but that's relative, like I said). If it's something that only gets released in Japan it'll have that JDM-tax attached to it.
It would be nice to have a have a prettier alternative
Old 09-03-2012, 11:14 PM   #12
motofan
Drives: 10 VW GTI
-J
technically the impedance of an ideal resistor is its resistance. So you cannot say it was wrong.
motofan is offline   Reply With Quote
The Following User Says Thank You to motofan For This Useful Post:
Old 09-04-2012, 11:48 AM   #13
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 09-04-2012, 07:31 PM   #14
RebornS14
RebornS14's Avatar
Drives: S14K
heck yeah @ $240 est.
RebornS14 is offline   Reply With Quote
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
FR-S / BR-Z Racing Seats!!! vividracing Interior Parts (Incl. Lighting) 8 06-19-2012 08:07 PM
